Hello, Just bought a wing keel 250 after much reading here. Thanks to all for their participation. The boat has a new design rudder but, I think, a push pull steering system. Is conversion to a pull pull type absolutely necessary? Also in the lazzerettes on each side of the dinette there are plastic bags of sand (maybe 300 lbs total). I am a bigger person 230 lbs and when I stand at the wheel this might help balance me out is this correct thinking. Should I remove it if I ever trailer it? Thanks. C Wray
Hi Chris.... welcome to the forum and congrats on the new boat.
There have been several reported failures of the push pull steering cable... so I think prudence suggest that sooner or later the cable should be replaced with the pull pull upgrade or an open cable system. You might check the sheeth of the cable as it bends out of the pedestal for any signs of cable break through... but I doubt advance warning will be obvious.
The c250 tends to set with the water line low aft. The result is too much aft mast rake which contributes to weather helm. The bags are an attempt to deal with that. If you were to trailer a long distance with a marginal pull rig then removing the bags might help slightly. btw...since the c250 was designed... the popular use of four strokes and starters has seen motor weight almost double. This contributes to the need for some balance.
A lot of C-250 sailors carry sandbags, so they probably have a reason, but, I'm curious... if excessive weather helm is a problem on the C-250, why don't you guys cure it by tilting the rig forward slightly? I'm not familiar with the C-250 rig, but it seems that would be better than carrying sandbags, which occupy storage space, make the boat sit a little deeper in the water and are generally detrimental to acceleration and boat speed.
I don't know of any water-ballasted C250s that carry sand bags. I know a number of wing keel C250s that do. They typically carry them under the v-berth to lower the bow and add some additional ballast. I've heard local C250 wing owners complain about being under-ballasted. Without the additional weight up front, the bow nuckle is above the waterline. The water-ballast model does not suffer the same fate.
BTW, I would assume tilting the mast forward would not help eliminate the additional drag that results from a squatting stern. Not only does a heavy outboard contribute to the "squat" as Arlyn suggests, but two people sitting in those stern seats has an even greater impact.
I used a different method to achieve the same result in my 250 wb. I abandoned the single group 24 battery in the aft compartment and installed two group 27 batteries, one in each V berth. The wife did complain a bit about the lost storage space though. It also makes it a lot easer to check the water level in the batteries.
Like you, I have two batteries in the V berth....both 6 volt golf cart batteries weighing 70 lbs each. I made a battery box and mounted it onto a piece of plywood that is cut near the hull sides to distribute the weigth and keep it from moving around.
Under this, I placed some 1/2 inch carpet pad to correct the small imperfections in the surface of the locker and cushion the whole during bow pounding.
It was something like a puzzle to get the plywood with the box fastened, into the locker.
I have my forestay as tight as it will go all the treadeds on the turn buckel are bottomed out. I have heard of people taking 3" out of the forestay to get the mast farther forward. It still would not matter the boat is stern heavy and with my 240lbs and family it get worse. As I learned from my dad during our racing days get as much of the dead weight out of the stern and into the bow. When we had our 22' boat before every race we would take all the dead weight out of stern storage areas and lay it in the v-berth. On my 250 I made a bag to hold sand to match the v-berth storage area I got it as far forward as possible and I also moved my 2 batteries from the stern storage area to the bow storage area. The boat sits level in the water and I have a 15hp Honda on the stern as well. The only problem I have now is as the 12 gal water tank gets empty (bow) the 18 gal head holding tank(stern)gets full the boat gets alitte stern heavy again. Before I made the sand bag changes we did test sails. After adding the sand the boat was more balanced and preformed quite well even before we got the 3rd gen. rudder. I still am able to store sleeping bags blankets spare clothes & the pop top cover in the v-berth storage. I was very UNHAPPY with the c-250wk before I made the adjustments. We don't have any racing or sailing club at our lake so I don't race but I have play raced with a buddy who has a Capri 23 in light to moderate air and we held our own.
I have 210lbs plus 2 batteries in the v-berth of Daylight Again. This makes the boat sit level at the dock. I do have a 15hp Honda outboard and a 18gal holding tank in the stern. The sand I used was out of sand bags you put in the back of a pick up truck to get better traction in the snow and ice. I bought 3 bags that are canvas with a plastic inter lining. I over sized the bags and put about 70lbs in each bag to get the sand to mold better to the v-berth. I also pushed them as far farward as possible so I had room for the batteries.
Matt, you must have our rockets confused with the Mac 26X. I can understand your confusion, though, as it must look like we are planing as we sail past you <img src=icon_smile_big.gif border=0 align=middle>
Mark, You will be passing me really fast now. The boat is on the hard and I'm getting ready to raise the mast for Christmas lights.<img src=icon_smile_big.gif border=0 align=middle> A guy at our lake has A big weight under his fore deck. I am trying to remember what it is. I want to say a big cement bag that has solified in place. If not that, something similar to help distribute weight. We have the gambit of people that prepare for races by removing everything before a race. You have to be careful not to trip over motors, extra sails, barbeques and god knows what else. Me I usually load a 5lb bucket of ice and beer and soda. Just helps when the wind picks up. I always win when I come in with a smile <img src=icon_smile_cool.gif border=0 align=middle>
Poor 25 owners, they are just so used to working and maintenace all of the time that when it's raining and snowing they just can't relax and enjoy life...
<img src=icon_smile.gif border=0 align=middle>
they have to (attempt) make fun of our fantastic sailboats.
I think 25s are great and certainly our 250s have some flaws, and when life and I become perfect I'll be able to go to their site and make fun of their wonderful boats.
Until then, I guess I won't have to learn how to work on exterior teak maintenance and so on.
Vic
"Leon's Dream" wonderful 250WK - #660
Happily docked (and sailing) in Lake Oroville - Northern California
Now Vic, lets not get nasty, I didn't write one derogatory remark about the 250. In fact I think I was praising them. I have a 25 because that is what I was able to find at my time and place. My wife was pushing for the wheel and those seats way in the back, but our finances said this is what you are getting. I was pleased to see though that the Cat 250 was considerably lower priced than the hunter. If we were to have gotten a new boat the cat 250 with wing keel would have won hands down. As it is wood working is one of my hobbies, as well as the fiberglas work I get with the old corvett my wife wants to sell. In reality the wood work on the 25 is verey low. I used Cetol (sp.) last year on external wood and it doesn't look like I will have to do anything to it this year at all, probably next year too. The interior is in great shape with no work on my part, and I don't see any need in the near future to do any. The main projects I see are similar to ones I see 250 people doing; insulation of the icebox, and changing the wiring. Sorry for taking so long to get all this out. I just want to say, "I like to sail, when and where I can. I also like to just mess about in boats, be they afloat or not." Have fun in the water or on the hard <img src=icon_smile_approve.gif border=0 align=middle><img src=icon_smile_approve.gif border=0 align=middle><img src=icon_smile_tongue.gif border=0 align=middle>
I bought a c 250 #614 this July. I have the 3rd generation rudder and a 9.9 honda 4 stroke hanging off the back. I have me rig pulled as far foward as possible. I have never had water in the water tank and feel no need to put sand in the v berth. I don't have much time at the helm of this boat, but I do have extensive time racing small and large boats. This boat handles as I would expect it to. It is a little tender for a boat of this size, but my weather helm is not what I would consider unacceptable. Pull your rig foward before you put any sand up there. MHO.
I put sand bags in the v-berth after pulling the rig forward. But before the 3rd gen. rudder was available. Other reasons I did it, 15 hp outboard, wheel steering, 11 gallon holding tank (now 18 gal)and 2 batteries with all that weight plus my 245lbs and 3 family members the bow was so far out of the water under sail and sitting at the dock with no one on it something had to be done. With me standing at the mast and the forestay as tight as possible we still had close to a 5" rake. Adding 210lbs and moving 2 batteries to the v-berth with the water tank 1/2 empty and the holding tank 1/2 full the boat sits level at the dock and the rake is where I want it 1". I don't know if I've learned to sail the boat better or if the weight added to the v-berth, pulling the rig as far forward as possible and adding the 3rd gen. rudder, but the weather helm and the tenderness everbody talks about and what I experienced before is gone! We sailed the day after Thanksgiving in 15-20 and at sometimes 25-30 knot winds with 1 reef & the jib roled into 100% from 135% had no handling ploblems no tenderness or weather helm I've heard of the c250 broaching when on a reach and going into rudder lock. I have never had either of those problems. One must ask, is it luck or the weight modifications.
Hey guys...I bought my wk250 last summer and haven't sailed it yet. This is the first I've heard of this issue. Is there a real problem if I do nothing on this matter? I really don't want to make any of the changes mentioned unless I really have to. I don't race. Are there any serious problems leaving the boat as is? Thanks
Adding ballast to the v-berth has not been done by everybody so I would say it is not necessary but the boat is more balanced and sits level with the weight added.
river, we sailed our new 250 for three summers without adding anythng to the vberth without any problems. but this past spring we added shore power which included an inverter, second larger batter and charger to the back of the boat and we could see it was not sitting level with all the added weight (just slightly, at the dock) but figured with our added weight while sailing that it would be a benefit to add a few sand bags to the front. it made a huge difference. it doesnt take up as much space as you think, and since we dont use that area for storage anyway, we decided to give it a try.
