The ADJ 12 will be O.K. in lighter winds, I'm estimating up to about 12 kts. (depending on how big a headsail you are flying). In higher winds, the aluminum tubing will buckle under the stress.
When sailing with white sails, you need a whisker pole for two purposes: (1) to spread out the sail, exposing as much sail area as possible to the wind, and (2) to keep the sail from collapsing from its own weight in light air.
When you are running in <u>strong</u> wind, you really don't need a pole to keep the sail from collapsing. The strength of the wind will hold it up. If you sail downwind without a pole in strong wind, any disadvantage you have from not having a pole will be very slight.
On my C-25, when I don't plan to use it, I slide the pole between the port side of the companionway ladder and the bulkhead that forms the galley sink. When I plan to use it, I store it topsides. I tied a short piece of 3/16" line in a loose loop around the grabrail on the coachroof. Then I clip the piston clip (on the end of the pole) through the loop, and lay the pole along the inside of the grabrail.
I don't know what pole I have other than its a Forspar & its lightweight aluminum tubing that is expandable (a lot like a boat hook w/ different ends). We use it with our jib when the air is light - particularly when close to a run or wing-on-wing.
I have used the adj 12 for several years now and it seems to be very adequate for at least the 110%. I store it starboard topside by clipping one end to the mast raising stanchion eye and the other to a short loop of rope thru the forward life line termination eye. It is completely out of the way there, doesn't rub on any boat parts and is easy to access and store.
Thanks all - SO the ADJ 12 it is and that leaves enough in the budget, maybe, for finally getting a wheel brake.
Anyone with an Edson wheel without the brake knows what I mean - single handling can be downright dangerous without one - should have bit the bullet 2 years ago.
Ensure that the brake is compatable with the pull pull upgrade. Not sure how it works... wasn't needed here because engaging the auto pilot clutch works same as a pedestal brake.
Gents.. The wheel brake does not interfere with the new pull-pull sytem at all. I installed one with the assumption that it could be used like a cheap autopilot for a few moments while rushing forward to reef, etc. It does basically lock the wheel in position, but does not hold the boat on course at all. With even minor wind shift, and any even small wave action the boat swerves off course very quickly.
Gclarke C250 WB.....coming out today for new bottom job, polishing, waxing, 2nd reef points, and other projects prior to resplashing in S.F. Bay in late November.
What about the wheel brake? Do most of the users find it to be able to hold the boat straight while you go forward to adjust the jib or perhaps even to the john below?
I was planning to add it to increase safety while single handing.
I rarely go on long tacks that would warrant an autopilot - but do need to automatically hold the boat stable for a minute or 2.
Thanks for the responses.
JKEY6 on 'All Keyed Up', C250 WK with Wheel, #447.
I single hand quite a bit. The wheel brake is my best friend. It will hold the course under motor to set sails, & it works well in lighter air 12 knots or less. Heavy air it will hold the course but not as long, but long enough to adjust a hailyard or a vang ect. In heavy air I might go below it get a drink would not go below to use the head though. The brake holds a course alot better with the 3rd generation rudder that it did with the 2nd. Plus the rudder does not move around while the boat is in the slip.
I have a 130% roller furled genoa. I tried a Forespare 6-12 twist lock pole but it was to Short!, I now use a HD Twist lock Forespar 7-17 and it is perfect for my use in light wind cruising and racing. When racing I store it by hanging it on the starboard life line with stainless steel Carabiners...it fits perfectly between the bow pulpit and the midship stanchion. Otherwise I just store it below between the stairs and the head in the aft berth. Yep..it cost more but it does the job and it has been very reliable for the last year. Happy sailing wing on wing<img src=icon_smile.gif border=0 align=middle> Steve Steakley
SSteakley - How much too short was it - that is how much did you have to roll in the foresail? For occassional use and $200+ difference I could stand a little off, of course I would not want to have to pull in to a 110% reef to go wing to wing.
Also,
Anyone else with the 130% Genoa try to use the ADJ 6 - 12 Whisker pole?
Looks like the wheel brake or the whisker pole will fall off the list unless the ADJ 6 - 12 will work.
I just added a wheel brake to my 250 WB a couple of weeks ago. I have the 3rd gen rudder and it works great. Will easily hold the boat steady for a quick run below, forward, etc.
I ordered it from West Marine. It literally only took about 15 minutes to install. However, there are no instructions and I had to look at the Edson info which came with the boat to figure it out. Just remove the compass to access the mounts for the brake shoes and lock. Word of caution, when installing the washers/retaining clip, be careful. It would be REAL easy to drop them down the well of the pedestal.
All considered, it's a great addition.
Bren Peterson C250WB, #642, "Ruah" San Antonio, TX
Jamie, The 6-12 is fine for cruising etc. I wanted to maximize the use of my 130% jib for racing and I use about 13'7" of the pole give or take a few inches depending on winds etc. The 6-12 is adequate and will add lots of trouble free downwind sailing. If you plan to race...I would spend the extra boat units, every second counts, Steve Steakley
Looking at the post dates, I think this topic is old, but I'm looking into buying a pole, and it raised a few questions. Anybody implement a down or up haul? Also how high off the deck did you mount the ring on the mast. Thanks any help is appreciated.
Brad, I installed a 4'x1" track on the front of the mast and my ring is on a car that slides up and down the track. The track may have been over kill but I thought I might need the versatility some day. How high you install a ring depends on the size jib you have. You want the pole to be level when it is extended....So I held the pole extended and marked the mast as we were sailing to determine the best height for the ring. Then I installed the track to allow for travel up and down from that point. I have never considered a down haul for the pole and have used in low and higher winds and did not have a problem that might require a downhaul. There is definitely a limit on the wind you want to use a pole in, especially if there is a chance for a sudden wind shift that can cause things to get out of control fast...had one of those experiences and when winds excede 10 knots I will think twice about using a pole...we were literaly surfing with 7+ knots showing on the GPS and the wind shifted significantly, fortunately nothing broke but it got real crazy fast! Have fun Steve
Go to the Forespar website and read their article and suggestions on type of pole to use for boat size and how to rig it. I think you will find that the lesser pole may be inadequate for windier conditions like we generally have on SF Bay where 10 to 12 knots is considered hardly any wind. They recommend storage out of the weather. Jim on Hey Jude and myself of Sparky store them below a la the tech tips. Jim cut the holes under the aft berth. I hung mine below the starboard berth on a couple of pole holders (or whatever you call them). They are only taken topsides when deployed.
I don't usually come in and read the 250 site but here is what I did for a wisker pole. Regualar poles are $100+. I go an extendable boat hook. The extendable pole used for fending off. The one I got extends out 16 or 18 feet cant remember exactly how far. I bought the end fitting for a wisker pole = same size as the dock pole and epoxied it into the end handle of the pole. Now I have a two function pole and it was only $35 for the pole and $12 dollars for the fitting.
