In dealing with a keel wire failure issue with Frank, he has given me a new 3rd generation rudder. However, the installation instructions only said to change the pintles from my 2nd generation rudder with no diagram nor measurements. Unfortunately my boat is in storage 135 miles away and I need help with this simple instruction. Do the pintles come off the aluminum head used with the 2nd generation kick up rudder? If not what size do I purchase from say West Marine? Frank gave no instrucitons as to where to place the pintles on the new rudder. I did notice a "cut out" on the starboard side fo teh rudder. Does this help in placing the pintles? Can someone give me correct measurements?
You don't indicate which boat you have... if you have the water ballast...I may have the drawing from Catalina for it...let me know and I will look. Someone sent it to me but I'm sure that I don't have drawings for the wing.
The pintles may could be used from your kickup head... but they would need mounts which will probably include the pintles as well.
As to the boss on the rudder... not sure but that may be a flat place on the rudder for mounting a receiver for a wheel steering control arm.
