 Closed up for the winter -- I thought
Initially Posted - 11/01/2010 :  20:50:31  Show Profile
I just realized that I spent a couple of hours yesterday getting the boat covered and ready for winter. Tonight, I just realized I left the porta-potti on board. Damn! One more trip to the marina. No, I'm not going to risk freezing the contents.
1999 C250 SR/WK #410
Bay Village, Ohio
Sailing Lake Erie
Don't Postpone Joy!
sweetcraft
Response Posted - 11/01/2010 :  21:42:33  Show Profile
You don't how close I came to doing the same. The potty is now in a heated shop as I get ready to do the task. Wonder how cold it would have to get to reduce the flow or turn to ice?
Patrice C25
Response Posted - 11/02/2010 :  05:14:10  Show Profile
Usually, water have to be trap into enclosed area to crack it's container when it freeze.
If the water level have room to vary, you will be fine.
My ice cube tray in my fridg is made out of plastic, and it doesn't crack every time ...
Response Posted - 11/02/2010 :  06:29:16  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Patrice C25</i>
<br />My ice cube tray in my fridg is made out of plastic, and it doesn't crack every time ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Plastic ice cube trays also are tapered outward from the bottom of each cube so that expansion below can push the frozen surface upward. Is your porta-potty designed that way? If not, I suggest emptying it. The cleanup next spring could be "tedious."
Response Posted - 11/02/2010 :  06:35:18  Show Profile
The truth is, I'm more concerned over the "clean" side of the water tanks. The holding tank is nearly empty. Probably the worst part is that I did a particularly good job of lacing up the back of the tarp.
