I have a 1979 Catalina 25 that has what I believe is a standard water supply setup: small tank on starboard with a lever pump sink in the galley and opposite the toilet. Both sinks/pumps are above the level of the tank. We bought the boat in April and have not used the water system at all. This weekend when I was winterizing and covering the boat I put some pink antifreeze in the tank and tried to pump it throught the system, but had no luck (it felt like there was no pressure in the system). Do these things need to be primed? If so, how and how often to keep things working? If not, any other ideas?
This may sound a bit crude, but to get mine going I turn 'em on then start sucking on the faucet. Previous owner clued me in on it. You'll feel a bit silly and you'll get a little sip of antifreeze, but it works(the boat kind's not hazardous).
They need no priming, other than working that handle back and forth quite a few times quickly to get things started. Check your system for any blockage - either in the lines or inside the pump/faucet itself. When I first bought my boat, I cleaned the insides of the pump/faucets. Had all kinds of strange pink algae/jelly-like stuff inside. Yuck.
I found out once that if you overfill the tank via the deck fitting water will come out of the pump at the sink. Be sure to treat the system before you use it in the spring.
Also, when you check your tank and accessories, check your hoses-as if they have not been replaced lately, you will want to after you see the condition they are in.
I don't know how stuff grows in there-but they will probably be BLACK with crud.
Mine also didn't work but a replacement at Boat US was not that much and now it works great. There are also repair kits for most of the manual type faucets. john on ms achsa #77
