Does anyone have a factory installed marine head in there 250.I was told the factory made that an option starting with the 2000 model. Before then the dealer installed it as an option.If so is anyone as dissatisfied with the cheap parts & installation. With the holding tank being black there is no way to tell if it is full. Due to the cheap 2" hose they used from the head to the tank the smell is terrible.
I installed a marine head in a '96 boat... and if its used while on a port tack the exhaust from the vent drifts across the cockpit rather unpleasantly.
There is also a very slight odor permeation below unless the tank is treated which seems to cure the problem completly.
I agree that a black tank while it may be friendly to some by not reminding them of the contents within... would be a detriment. With the clear tank, I simply set my flashlight on its top from within the wet locker and the level is visible looking from the aft berth.
However, the factory installation provides it seems a larger tank, I felt that a 13 gal tank was the largest I could get into the area. In fact, I think I tried the next larger size...and could not get it in.
The tank is in the stern storage area with the battery so it can't be seen and it is only 11 gallons. I have a horror story to tell about this holding tank if anyone is interested. After that I replaced the whole holding tank set up and added a tank tender monitoring system. This year I am going to replace the flushing hoses from the thru hull to the head and install a permanently mounted microwave. These projects seem to take forever, the boat is in the water. I go there with all intensions of working on the boat but something comes over me and the jobs take 4 time as long as it should.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Does anyone have a factory installed marine head in there 250.I was told the factory made that an option starting with the 2000 model. Before then the dealer installed it as an option.If so is anyone as dissatisfied with the cheap parts & installation. With the holding tank being black there is no way to tell if it is full. Due to the cheap 2" hose they used from the head to the tank the smell is terrible.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> The tank is in the stern storage area with the battery so it can't be seen and it is only 11 gallons. I have a horror story to tell about this holding tank if anyone is interested. After that I replaced the whole holding tank set up and added a tank tender monitoring system. This year I am going to replace the flushing hoses from the thru hull to the head and install a permanently mounted microwave. These projects seem to take forever, the boat is in the water. I go there with all intensions of working on the boat but something comes over me and the jobs take 4 time as long as it should.
Bryan Beamer
Yes, I am interested in your "horror story." I have a 2002 model in which the marine head system as yet to be put to the test...anything I should watch for next season regarding this?
<b>"With the holding tank being black there is no way to tell if it is full." - Bryan Beamer
"I agree that a black tank while it may be friendly to some by not reminding them of the contents within...would be a detriment." - Arlyn Stewart</b>
This season was my first with a marine head and it, too, has a large black holding tank which I can't determine when it is full. Anyway, from the start of the season I was using a kind of dead reckoning method(keeping a running track of usage)to determine the tank level. One day I was out sailing in some good wind on a starboard tack, heeling over pretty good, when I noticed a deep blue liquid stream running down along the portside toe rail and over the side through the scupper in front of the winch. After an instant of thinking, "What the F... <img src=icon_smile_shock.gif border=0 align=middle>", it dawned on me. <img src=icon_smile_dissapprove.gif border=0 align=middle> It was deodorized blue effluent that was relieving itself from my half full holding tank through the topside tank vent. Needless to say, I immediately released the traveller, eased the mainsheet, and came off the wind to lessen both the heel and the flow.
The moral of this story is, unless you have some sort of vent restrictor, empty your tank around half full...oh yeah,...and use a tank deodorizer because it's better to have a nicer smelling blue stream than the raw alternative! <img src=icon_smile_dead.gif border=0 align=middle>
I'm glad I haven't had that problem. On the 250 factory installed holding tank the vent is about 2' straight up from the tank the thru hull is out the stern on the port side. I've had the tank totally full have never had the blue river flow. Now going down wind and someone uses the head you do get the blue river smell.
I am heading towards the boat for the rest of the weekend so I will tell the horror story Monday.
I picked up my boat from the dealer April 2000. They told me they had no way of testing the head system because the water is sucked out of the lake to flush. I got home and wanted to see if the flush would work okay so I took a bucket of water poured it into the bowl when I started to pump, the water ran out on the floor. After cleaning up the water and tightening down the 2 bolts that connect the discharge hose to the pump I tested it again and everything worked fine. I thought good, easy fix I will not have any problem with this again. How wrong I was. After launch I though I would monitor the usesage of the head to know when it was full. I said to my self when the tank gets full it will not let me pump anymore or it will flow out the vent hose.
After 3 weekends it was not full so I thought. I went down to the boat by myself the 4th weekend to relocate the batteries to the v-berth. I climbed back thru the stern berth (we keep it ready for a bed with sheets and a comforter)and I noticed my knee was getting wet though the cushions and the bedding. I first thought it was water. Then I smelled it and it smelled like the blue tank deodorizer and pee. I pulled the bedding and the cushions up and I could ring the (we'll call it stuff)out of the cushions. I cleaned up the area where the cushions go so I could climb back there and not get sick. I opened the stern storage area door. The stuff was every where about 1" deep This took an hour to clean. As I was cleaning I was looking for what might have caused this. I check all the hose connections they were dry. I finally told myself I was going to have to pump more into the tank to see where it was coming from so I did.
I pumped, then went back and looked. Finally I saw the stuff running down the sides from the top. I thought I had a crack in the tank I had to bend my arm in a funny way just to get it to the top of the tank Then I found it. A 2" threaded hub on the top of the tank and the 2" plug in it was at least 3 full turns from being tight. THE FACTORY INSTALLED THE TANK AND FORGOT TO TIGHTEN THE PLUG!!! Thru the little storage door you can't even see the top of the tank I did not think to feel up there why would I.
The problem I had now is 2 berth cushions are full of stuff. So I took them home. The covers were zippered so I was able to wash them in the washing machine. The cushions I took outside and flooded with a hose until the blue stuff was gone. I did this twice. I rang out as much water as I could and it still took 4days of direct sun to get them dry. This whole ordeal took me at least 10 to 12 hours to fix and it could have been avoided in 30 seconds if only the plug was tightened during installation.
The next 2 years still not knowing how full the tank was I would empty every three weekends. but on 2 occasions during the summer it would get too full and during the week it would heat up and flow back to the head filling the bowl, and go all over the floor. One time this happened during 9/11. Our reservoir was closed by the state from 9/11 to the beginning of October. The first chance we got to go to the boat we found this, you can imagine the smell when we opened the main hatch. The hose Catalina uses from the head to the tank is the cheapest black water hose on the market. It does not leak fluid but it does not hold odor. The hose always has stuff in it because of the way it is run. The deodorizer does not stay in the hose it stays in the tank. A closed up boat for 5 days without air movement can make everything around the hose smell. That is why I changed the discharge hose to a better one and I use a different product called Odorlos in the tank. I am very happy with it. I now open the main hatch after 5 days and there is no stuff smell. I hope this helps someone, I would not wish this HORROR on anyone.
Sorry to read your horror story. I suggest you talk with Cat about replacing the soiled cushion.
I have had several problems after the launch of my Y2K C250WK and I have been very impressed with Catalina's willingness to make good.
Catalina fixed several rather minor problems in the field, while the boat was in the water. It takes them quite a while to get to you, but they have been very good reacting to my issues; that by the way were a topside leak (winch)and a hairline crack near the front hatch. Once at my boat the 'Catalina warranty guy' spotted a couple of minor finishing issues and buffed them out as well.
I'd ask, I can't imagine trying to clean the rear cushions due to the marine head overflow.
JKEY "All Keyed Up" C250WK
PS: Still enjoying your wheel pilot cushion - thanks.
I am in the process of replacing the porti-potty with a marine head. I have moved the batteries forward into the v-berth and rewired them to the panel.
I have also installed a 13 gallon todd tank behind where the battery was located, but still need to install the head and run the hoses.
Any recommendations as where to place the vent and any other suggestions on running hoses etc would be greatly appreciated.
Brad Wagner C-250 Wing Keel #361 Lake Pleasant, AZ
Brad, the West Marine advisor says the vent line should not be lengthy.... and use the best quality hoses you can find.
I have the same tank, but chose to mount it immediately aft of the wet locker bulkhead. With the tank in the aft compartment, I'm thinking the fill line would run thru the bottom of wet locker and along the bottom of the port storage bin in the aft berth along the same channel as the bilge hose.
btw, I was concerned that my installation of the Todd tank with side inlet and outlets, would significantly reduce the capacity of the 13 gal tank. However, testing indicated that the 13 gal rating is the usable capacity between the upper point of the discharge outlet (point at which pump out suction fails) and the vent line.
I thought about mounting the tank behind the wet locker, but the admiral gave me the thumbs down on the idea, so I had to settle with the area behind the aft berth. Because of the run I am installing a Willcox-Crittenden(sp)Newport electric head with the built in maserator. I will be taking the flush water out of the lake through a thru-hull and installing a treatment system in-line so every flush is treated.
Would you recommend puting the vent in the stern or out the port side?
I had planned to put the deck fitting just forward of the port stern seat, any thoughts?
Bryan, Wow what a horror story. I usually find humor in a hard luck story....but found very little in yours....wheww.
Betting the next look at my holding tank aft of the wet locker includes a search to see if a leak would go into the bilge or aft berth. I'd check right now...but its cold n rainy out thar today. I think but am not sure that it would drain into the bilge thru the holes associated with the bilge hose and intake hose for the head.
As for the vent line, you want it at the least offensive location. When the head is used, the vent line of course will exhaust... if a sensitive crew is aboard... it might be time to alter course to suit the wind. Use of treatment greatly helps.
Jkey not sure what you meant about the pilot cushion.
Brad The vent outlet on the factory installed holding tank is on the port side of the stern between the swim ladder and the edge of the port side, close to the top of the stern. Trust me with this next part. You want to use Sealand Odorsafe hose for the 11/2" discharge hose going from the head to the holding tank. It costs about $8.00 a foot (very well worth it). I think West Marine uses it by name in their Head to holding tank advisor. I also used the same hose going from the tank to the pump out deck plate. The pump out deck plate is located right in front of the port stern rail seat. The 3/4" vent hose is also the same Odorsafe hose.
Arlyn
I wish it was possible to have it go into the bilge. From the stern storage area the only way to the bilge is thru the aft berth. I sure if the cushions would not have soaked up the stuff it would have made it to the bilge.
