 Mast to Mast step connection
lewalskim
Initially Posted - 12/03/2002 :  08:47:56  Show Profile
I noticed this weekend that my mast is connected with a threaded bolt and lock nut. It doesn't seem that Catalina would have designed it this way, so could someone tell me what is normally used? I will probably never unstep the mast but I'd like a strong bond at that point.
Mark Lewalski
C250WB #206
Safety Harbor, Fl (aka Tampa Bay)
BJ Wagner
Response Posted - 12/03/2002 :  10:20:00  Show Profile
My boat is a 1998 and it has the exact same thing. I have been sailing it that way for a year and half in a variety of winds and have never had a problem.
I have even questioned our local dealer about the fact that it doesn't seen to be as tight as it could be and he said it was fine.
Others on the forum have much more experience and time with their boats and I'm sure one of them might be able to give us more information on this.
Brad Wagner
C-250 Wing Keel #361
Lake Pleasant, AZ
Response Posted - 12/03/2002 :  10:35:30  Show Profile
I drilled a hole near the end of the bolt (use a very sharp bit on stainless) and use a ring to secure the wing nut and enjoy the feeling of comfort about it.
<img src="http://www.cox-internet.com/arlynstewart/images/helming.jpg" border=0>
Arlyn C-250 W/B #224
[url="http://www.cox-internet.com/arlynstewart/"]Arlyn's C250 Mods n Cruising Stories[/url]
Response Posted - 12/04/2002 :  11:48:35  Show Profile
<b>"I noticed this weekend that my mast is connected with a threaded bolt and lock nut. It doesn't seem that Catalina would have designed it this way, so could someone tell me what is normally used? I will probably never unstep the mast but I'd like a strong bond at that point."</b>
The mast step bolt just keeps the bottom of the mast from moving laterally and is not intended to be the primary means of securing the mast to the deck, that is the job of the shrouds and stays. Also, the mast step bolt should be just snugged and not torque excessively because an overtightened stainless steel bolt can compress the softer aluminum mast which in turn can weaken or crack the spar. To prevent over tightening, some mast step bolts come from the factory with a wing nut that is meant to be tightened by hand, preventing over tightening of the mast step bolt. If you are concerned about the (wing)nut loosening and coming off, you could use a locknut instead or you could do as Arlyn did and drill a ring hole to secure the nut. Another option, if you have the threads available on the bolt, is to add a second stainless steel nut and tighten the two nuts together(against themselves). This will keep the nuts locked on the bolt and, since they are torqued to each other, they will not put undo stress on the mast.
Don Lucier, 'North Star'
C25 SR/FK
On the hard near Lake Erie
