Greetings! I have a question about your soft-link set-up. I downloaded the photo awhile back and have been studying it. I have been trying to decide whether to go this route or invest in a on-the-market kit. Here's my question based upon how I understand your system to work. When the soft-link is connected and "at rest," will the rudder be pulled completely to the starboard side (tiller handle to port)? It appears to be that the bungy will always have tension when the tiller is positioned anywhere except in the starboard tack position. This will require that the tiller never ne unattended when the softlink is in use, otherwise the bungy will pull the rudder starboard. Is my understanding correct? I like the idea of your system (not to mention the cost)and the fact that it can be detached and stowed easily when not in use. I just want to make certain that I understand it completely. Your feedback is appreciated.
Yes...your understanding is correct. There is a slight loading on the tiller... not much... though of course too much for unatended operation.
I use the system only when docking or loading on the trailer... where it does a very good job. It is so easy to clip the sister clip to the rudder when desired and to unclip when not wanted. There is nothing really to store as when uncliping from the aft rudder eye...I clip the line to a line loop from the upper pintle. The loop being the right length to provide a straight forward motor position. This will be the normal mode for motoring which of course offers no loading or control from or to the tiller.
Arlyn, I went to your website and saw the 'soft-link' photo. Please tell me what a sister clip is and where you buy bulk bungee cord. I imagine that the swivel for the motor is loose all of the time, therefore you'd have to have the line/bungee system hooked up all the time, right? And yes, I've noticed that you love bungee!
Thanks for putting all your upgrades and mods online with photos to share with the rest of us.
Mark Lewalski C250WB #206 Safety Harbor, Fl (aka Tampa Bay)
The sister clip that I use on my softlink is bronze from the hardware store and has an eye on one end and opening jaws on the other which are opened by use of the thumb on a lever (easily done with one hand).
On my old Honda, the turn lock/friction adjuster was a bolt which was difficult to get at... so I left it loose all the time. When rudder linking was not wanted, the line was released from the rudder an attached to a loop of line that hung from the upper pintle. This loop was sized so that the motor remained centered.
The new Honda has a turn lock/friction adjuster on the front in the form of a handle so I use it rather than hooking the linking line to the loop. So, yes the link is hooked all the time eithr to the eye on the aft of rudder or the loop from the pintle depending on if you have an easy to use turn lock.
Bungee can be bought at the home center or hardware store. However, all bungee is not alike. Bungee from a marine chandelry will usually be UV protected/resistant. This means that it will last two season in sunlight compared to one or less for non protected. My suggestion is not to fool with the non protected types. White cords tend to do better than colored.
Yes, I love bungee. It serves many task on my boat. Buy extra as there is always another project it will serve. Also get a hog ring tool and stainless hog rings. These are the little pointed rings that crimp closed by the tool and make the splice when installing bungee on a sister clip or doubling back to itself when securing within a bungee hook. West Marine and others also sell made up bungee chords with stainless hooks. When these play out... I renew the bungee within the valuable hooks. Often its helpful to custom size the length of a bungee chord.
Thanks for the kind words about the web site...my son finally showed my how to do it.
