A few people were looking for a heavy duty motor mount. Heres one I bought and never used. I bought it used, just never put it on.
This is model number 71090: H.P. Rating: Over 7 1/2 to 30 Motor Weight Not to Exceed: 169 lbs. Vertical Travel*: 9 1/2” (24cm) Mtg. Pad: Poly Mounting Board Dimensions W x H x T: 10 3/4” x 12” x 2” (27 x 30 x 5cm)
Here are the specs:
ALUMINUM AUXILIARY MOTOR BRACKET FOR 4-STROKE MOTORS
MODEL NUMBERS 71090 Raise and lower trolling and auxiliary motors on power and sailboats with ease Built especially for new 4 Stroke, heavier, high torque motors Extra Wide 11 1/2" (29cm) Black Poly Mounting Board for new, wider style motor locking clamps used on late model outboard motors Accommodates long or short shaft motors Motor Safety Cable included for added protection With 5 vertical running position lock bar to compensate for water surface and boat load conditions – Hard coated for added resistance to wear New, ergonomically designed twist lock safety knobs secure bracket in place Heavy-duty stainless steel torsion springs help counterbalance motor’s weight Easier to hold with comfortable, soft Hypalon grip handle designed to accept most style outboard motor locks Black satin Anodized aluminum body resists corrosion – Dubbed the “Black Beauty" Outboard Motor Bracket 2" Thick, Extra Wide Black Poly Mounting Board – Weatherable and maintenance free Aircraft Type Stainless Steel Hardware – For increased durability with nylon friction resistant washers
I will sell it for $195 + shipping. This sells new for $343.00. I cannot ship until I return from a trip on the 28th of feb.
Condition is very very good. A few flecks of white paint on the bracket that could be cleaned off. This thing is a monster and is really built well! I have actual pictures (not file photo), I will try to add them later today.
