 Pin Diagram
Alan Clark
Initially Posted - 03/09/2011 :  09:31:26  Show Profile
Does anyone have a pin diagram for the mast plug as to which pin is ground and which pin is what light (anchor light, steaming light etc.)
I am replacing the anchor light with an LED and want to test it while the mast is down and have a testor, just need to know which is which without spending 3-4 hours figureing that out. Thanks for your help..
Alan & Eileen
2001 Catalina 310 Hull #155
"Anam Cara"
ex-1987 C25 TR/SK #5612
"LEPRECHAUN"
Troy Ohio USA / Lake Erie-Catawba Island
ASA 101 103 104
"The clink of an anchor - chain, the 'Yo-Ho!' of a well time crew, the flapping of huge sails - I love all these sounds."
John 'Rob Roy' MacGregor
Response Posted - 03/09/2011 :  09:54:31  Show Profile
http://www.catalina-capri-25s.org/manbro/pictures/4-2-4.gif
Response Posted - 03/09/2011 :  10:14:19  Show Profile  Visit Prospector's Homepage
Alan - the ground wire has a larger pin than the others. Connect your Neutral to the biggest pin of the bunch, and you will be set to go. After that, just test all 3 of the other pins, and you will know which pin is which. It just takes about 5 minutes. (Been there, done that).
Alan Clark
Response Posted - 03/09/2011 :  10:40:11  Show Profile
You guys Rock!!! Thanks
