 outboard electronics
trptelf
Initially Posted - 03/18/2011 :  19:45:57  Show Profile
Can anyone tell me what this is called? Its in between our key switch, battery selector switch, and outboard motor.
Bill and Erin
Formerly of Cat25 WK/TR
and Cat25 FK/SR
KeziCat
Response Posted - 03/18/2011 :  21:20:30  Show Profile
It looks like a remote starter relay of some sort. I can see it has the typical two large terminals and two smaller terminals. What's the year, make and model on your outboard?
Response Posted - 03/18/2011 :  21:26:21  Show Profile
If it came off the outboard, it might be the rectifier/voltage regulator.
trptelf
Response Posted - 03/19/2011 :  04:39:11  Show Profile
Our motor is a 1987 Yachtwin with a remote start. The key switch is in the cockpit. All wiring between the battery switch, key switch, and motor pass through this unit. We have a problem with the starter engaging anytime the battery selector 1 is on, and we have to turn off battery 1 once the motor is started to stop the starter from turning over. This is with the key in the on position, not the start position. So we would like to know what this part is called so we can find a diagram and see where the wiring problem is.
So no one else has this on their boat? Ours in under the port cockpit seat. Our remote start is next to the bilge pump. Thanks for your input!
Edited by - trptelf on 03/19/2011 07:15:07
Response Posted - 03/19/2011 :  08:41:36  Show Profile  Visit aeckhart's Homepage
I have an 88 YachtTwin but not this set up. I haven't seen anything like it before and I've been on this forum since 1994. It is most likely an after market add-on, in which case you won't find any wiring diagrams other than what the PO left behind. it might be best to get an electrician to hash out the problem.
Edited by - aeckhart on 03/19/2011 08:44:15
trptelf
Response Posted - 03/19/2011 :  10:15:58  Show Profile
Thanks, I should maybe mention here that the PO had wheel steering set up, so maybe it has something to do with that. We apparently have an alternator on the motor (if we haven't blown it already), so I thought it might be a regulator. Thank you!
KeziCat
Response Posted - 03/19/2011 :  13:22:04  Show Profile
I thought I recognized it from somewhere. I have an 84 YachtTwin with electric start, and I believe the item you have pictured is in the BRP-OMC catalogue. (link below) Look under "OB Accessories-Remote Starting Kit". The item has showed up on eBay a time ot two as well.
I considered converting mine to remote once and I may still, but after looking at what was all involved it seemed like it would be much easier to lean over the transom and hit the button. I did add a remote control box with shift and throttle cables. A significant improvement over the tiller arrangement and probably the best upgrade I have done to my girl.
http://epc.brp.com/Index.aspx?lang=E&s1=79c0a765-1a27-41aa-996d-c77327925f98
Response Posted - 03/19/2011 :  13:38:35  Show Profile
Looks like a solenoid (electrically activated switch), and sounds like a stuck solenoid. It could be miswired, but that's how it will behave if it's stuck. You might ask a mechanic about giving it a shot of WD-40, or some other simple remedy... although it might be sealed so you can't do that. (Don't try it merely on my suggestion!)
Edited by - Stinkpotter on 03/19/2011 15:34:11
trptelf
Response Posted - 03/19/2011 :  19:29:12  Show Profile
Thank you!!!!!!!!!!
Response Posted - 03/20/2011 :  07:02:36  Show Profile  Visit DaveR's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Looks like a solenoid<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I think Dave's right. I've got a Johnson 50 that I had to replace the solenoid on and it looked an awful lot like your picture.
trptelf
Response Posted - 04/22/2011 :  08:57:31  Show Profile
We replaced the solenoid, no change, the solenoid was fine. We replaced the key switch assuming a short, no change, key switch was fine. I did notice when replacing the key switch that the old switch did not have a wire coming from "A" of which I thought was fine because I assumed it was for an "accessory". BUT the New switch had an "I" instead of an "A" for "ignition circuit". Diagrams show magnetos (of which ours is with a hot M and a ground M) both with an A, or an I, or both.
Does anyone know if I need a wire from the "I" or "A" going to the ignition in the situation of having the hot and grounded M's? If so, where does the other end go on the picture in the first posting? Thanks for your thoughts. It has been months now of trying to figure this out unsuccessfully.
