 Bimini on craigslist
eguevara
Initially Posted - 03/29/2011 :  20:12:08  Show Profile  Visit eguevara's Homepage
http://dallas.craigslist.org/dal/boa/2292875837.html
He tells me that it's 75" wide.
Do you guys think that this would fit on my boat?
I have a 1986 Catalina 25.
I can't get out to the boat till this Saturday and I'd hate for this deal to pass me by.
Thanks in advance.
-eddy
1986 C25 SR FK #5152
http://knoteasy.tumblr.com
http://www.flickr.com/photos/eddyguevara/sets/72157626204345986/
skybird
Response Posted - 03/29/2011 :  21:08:02  Show Profile  Visit skybird's Homepage
Eddy, mine measures 77" outside to outside on the attachment brackets and is pretty close to the edges of the coaming. I believe the 75" would fit even if you had to spring it just a little to reach. I say go for it!
Response Posted - 03/29/2011 :  21:14:03  Show Profile
I've been looking for a bimini....thanks for the heads up!
Response Posted - 03/30/2011 :  05:50:03  Show Profile
How long is it?
Is it a flat bimini?
Edited by - dlucier on 03/30/2011 05:51:32
Response Posted - 03/30/2011 :  08:34:59  Show Profile
Good price, hope you get it. When you buy one, take it out to the boat along with 2 washcloths or small rags, pieces of carpet, etc. With someone helping to hold it, open up the bimini with the ends on the rags to protect the deck from scratches (deck mounting brackets should also be attached), and position it where you want it relative to the boom, sheet winches, etc. Remove the rags and mark the deck where you want the brackets to be.
With luck, it will be wide enough to mount on genoa track cars.
Response Posted - 03/30/2011 :  08:45:41  Show Profile
The bimini should open up to be almost flat, as Don noticed.
I designed my bimini to be about 6' long and extend forward from the backstay up over the companionway about 6" for maximal protection from sun or rain.
How long is this bimini?
eguevara
Response Posted - 03/30/2011 :  09:17:21  Show Profile  Visit eguevara's Homepage
I don't know the length at this point. but for the price I don't think that it matters to much.
I just want a little shade, I don't care to cover the whole cockpit.
I hope I can install it on the track like I saw someone else do on a thread on here.
I'll keep you guys updated.
thanks for the help.
-eddy
Response Posted - 03/30/2011 :  12:38:13  Show Profile
I positioned ours midway between the boom vang and the end of the boom, it's 6 ft long, and covers part of the companionway. I can also stand up behind it to see the main sail set if I need to. We only use the bimini while sailing if the wind is very light.
eguevara
Response Posted - 03/30/2011 :  16:08:45  Show Profile  Visit eguevara's Homepage
I have one on my catalina 22 and it rocks on those hot August days when the wind just dies down.. and I end up anchoring... having a lil shade is nice sometimes..
-eddy
Response Posted - 03/30/2011 :  16:58:15  Show Profile
The one on your C-22 will transfer to the C-25. It just might be a bit short if you have a std rig. That's what we did with ours, and it does just barely fit under our tall rig boom. All I had to do was add appropriate mounts to the deck of the C-25. This way, I can use it on either boat.
eguevara
Response Posted - 03/30/2011 :  17:57:48  Show Profile  Visit eguevara's Homepage
well if that's true.. then I might have a choice then...
I'll keep you guys informed..
-eddy
Response Posted - 03/31/2011 :  09:00:24  Show Profile
If you do move your bimini from the C-22 and it won't reach the genoa tracks, please consider installing bimini tracks on your deck. I wish I had done it. They will give you much more flexibility in placement and may let you lean it back against the backstay when not needed. Mine rests on the cabin top, which is not ideal.
eguevara
Response Posted - 03/31/2011 :  15:25:52  Show Profile  Visit eguevara's Homepage
On the Catalina 22 it rests on the cabin top and I don't like it..
Thanks for the suggestion.
-eddy
Response Posted - 04/02/2011 :  07:04:58  Show Profile
Eddy....did you get this bimini?
eguevara
Response Posted - 04/02/2011 :  10:25:10  Show Profile  Visit eguevara's Homepage
I did. I went ahead and borrowed a truck from my friends in desoto and drove down to Ennis to pick it up. It's is very adjustable. So I'll be able to make it work. For now I left it in my friends garage until I get the boat moved. Once she's a Joe pool then I'll mount it. For $120 it was a good deal.
-eddy
Response Posted - 04/03/2011 :  19:19:34  Show Profile
Good luck with he project; the price is great.
At Ease
Response Posted - 04/07/2011 :  15:58:57  Show Profile
My local paper advertised a boat with a "bikini top"...wonder what that looks like.
eguevara
Response Posted - 04/07/2011 :  16:01:29  Show Profile  Visit eguevara's Homepage
depends on her measurements..
I prefer 36-24-36..
-eddy
