 Mast head crane/spinnaker halyard question.
Initially Posted - 04/03/2011 :  14:37:57  Show Profile
So while I had the mast down today I installed a mast-head crane and a spinnaker halyard. After I raised the mast, I'm not sure I like what I see:
My camera is zoomed in all the way.
I have the halyard tied off on the port shroud but it still looks like the new halyard will be rubbing on the CDI furler, does this look normal?
2005 Gemini 105Mc
PO 1987 C25 #5509 SR/SK
Tampa Bay
Response Posted - 04/03/2011 :  14:49:47  Show Profile
It does look like it's rubbing. Why not tie it off to the same spot the other end is shackled to when not in use?
Response Posted - 04/03/2011 :  16:36:16  Show Profile
Have you considered a cheek block or even running the halyard inside the mast?
Edited by - OJ on 04/03/2011 16:36:39
Happy D
Response Posted - 04/03/2011 :  16:36:47  Show Profile
It seems to me I remember some talk about the mast head crane being too short to properly put the spin halyard there. You might want to do a search on the forum for better info. I intend to build a crane that holds the spin halyard further away from the front of the mast.
I intend to get a lot done in my life but I'm seriously falling short lately.
Response Posted - 04/03/2011 :  17:55:42  Show Profile
I also had issues with the spin halyard fouling on the upper furling swivel that was solved by running both ends to the bow pulpit when not in use.
Response Posted - 04/07/2011 :  13:25:24  Show Profile
So Davy, What is the outcome on the masthead crane? Do I send mine back to CD when it comes?
Happy D
Response Posted - 04/08/2011 :  16:12:47  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Why not tie it off to the same spot the other end is shackled to when not in use?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Because it would rub like mad when it's under load?
Response Posted - 04/08/2011 :  17:49:33  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">So Davy, What is the outcome on the masthead crane? Do I send mine back to CD when it comes?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
So far, I've tied off the halyard like Don L. Tomorrow will be the first day out with it.
