 Can't find a cleaning tool
Ben
Initially Posted - 04/09/2011 :  15:04:07  Show Profile
Hi All,
I can't believe this product doesn't exist, but so far I haven't been able to find it. I'm looking for a manual deck wash pump. Essentially a manual bilge pump like the one pictured below, but with a long intake hose with a weight at the bottom, and an exit hose that I could use to wash down my deck or to fill a bucket. It would be nice if the shaft of the pump could clamp to a stanchion. Does anyone have any recommendations?
Thanks so much!
Ben
Beneteau 361
Viking Kitty
Columbus, Ohio
Response Posted - 04/09/2011 :  15:07:30  Show Profile  Visit britinusa's Homepage
In England, we used to have something like that called a 'Stirrup Pump'
[url="http://www.bbc.co.uk/ww2peopleswar/stories/73/a4514573.shtml"]found this[/url]
[url="http://www.alliedsprayers.com/StirrupPump.htm"]and this[/url]
and [url="http://en.wiktionary.org/wiki/stirrup_pump"]this[/url]
Edited by - britinusa on 04/09/2011 15:10:38
Kip C
Response Posted - 04/09/2011 :  15:44:07  Show Profile
Ben,
Check the plumbing department at Home Depot or Lowes. I know the one I'm a regular at has them.
Response Posted - 04/09/2011 :  21:30:11  Show Profile
Ben
If not, you should invent one, and I'll sign up for one.
Ben
Response Posted - 04/11/2011 :  04:15:39  Show Profile
Thanks guys, I'll try Lowes or Home Depot. if I can't find it there, I'll have my R&D guys whip one up for me to present to the stockholders. ;-)
Response Posted - 04/11/2011 :  05:14:56  Show Profile  Visit britinusa's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Ben</i>
<br />Hi All,
Thanks so much!
Just a thought, What's the bet that all you have to do is reverse the valve in that thing?
Response Posted - 04/11/2011 :  05:43:10  Show Profile
<br />I'm looking for a manual deck wash pump...that I could use to wash down my deck or to fill a bucket.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
To fill a bucket with lake water, I attach a line to a bucket then lower it over the side. I do this after anchoring if I get some muck on the foredeck. I also have a 1 gl plastic jug with a hole cut out at the top opposite the handle (line attached to handle as well) for the same thing.
NautiC25
Response Posted - 04/11/2011 :  08:22:21  Show Profile
Super Soaker?
lol
I'd love to hear the solution to this as I don't have running water at the marina.
Edited by - NautiC25 on 04/11/2011 08:53:55
Response Posted - 04/11/2011 :  09:08:05  Show Profile
If there is a hose available with a diameter sufficient to go over the end of the West Marine bilge pump, then 5 ft of such hose attached with a ring clamp. What about a 2-3 gal garden sprayer with pump? I know some folks use that for showering. My 3-gal. sprayer haS a shoulder strap that might work to lower it oveer the side to fill it.
NautiC25
Response Posted - 04/11/2011 :  09:39:35  Show Profile
I've already thought about a 12v RV pump, which should work great, but my batteries are already taking a hit from other electronics....
Response Posted - 04/11/2011 :  10:28:44  Show Profile
<br />If there is a hose available with a diameter sufficient to go over the end of the West Marine bilge pump, then 5 ft of such hose attached with a ring clamp. What about a 2-3 gal garden sprayer with pump? I know some folks use that for showering. My 3-gal. sprayer haS a shoulder strap that might work to lower it oveer the side to fill it.
For those with swing keels just attach a Y adapter to your keel cable hose? and then attach the pump above to the hose without the cable and pump away!
calden
Response Posted - 04/11/2011 :  11:41:01  Show Profile
How about a combo boathook/spray gun?
http://www.bridgenorthbailer.com/
Ben
Response Posted - 04/11/2011 :  12:20:49  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">To fill a bucket with lake water, I attach a line to a bucket then lower it over the side. I do this after anchoring if I get some muck on the foredeck. I also have a 1 gl plastic jug with a hole cut out at the top opposite the handle (line attached to handle as well) for the same thing.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Don, I've done the ol' bucket on a line routine many times over the years. On a hot summer day, the bucket starts to get mighty heavy after a short while. That's why I'm looking for a smarter way to do the job.
Justincase
Response Posted - 04/14/2011 :  11:05:49  Show Profile
Is this what you are thinking of? It's for a kayak, but a hose attached on the suction, might do what you need it to do.
http://www.mec.ca/Products/product_detail.jsp?PRODUCT%3C%3Eprd_id=845524441893985& FOLDER%3C%3Efolder_id=2534374302701329
Response Posted - 04/14/2011 :  16:26:00  Show Profile
<br />Don, I've done the ol' bucket on a line routine many times over the years. On a hot summer day, the bucket starts to get mighty heavy after a short while. That's why I'm looking for a smarter way to do the job.
Actually, I don't wash my boat at sea. I do it before I leave the slip.
Response Posted - 04/14/2011 :  16:57:29  Show Profile
And exactly how is pumping some 20-30 times going to keep you cool?
Response Posted - 04/15/2011 :  07:32:17  Show Profile
Replumb the marine AC to dump on the deck.
