 Running rigging
booyacht
Initially Posted - 04/12/2011 :  12:30:47  Show Profile
Would anyone mind posting a few pictures of your running rigging on the 250? This is my first time setting it all up and I know I'm close but want to verify. I'm using the manual but it doesn't seem to list everything that I have.
I'm also concerned about the setup of the cdi furler, where exactly you run the line to roll it back up. I have it going thru the eyes to the port cam cleat.
Also, I appear to have an extra jib Halyard. It runs up the mast like the main halyard but empties forward. I don't know what I'd use it for since the furler has its own raising system.
Anyway, thanks for any tips you can provide.
Will Osborn
2000 C250 WK #478
Response Posted - 04/12/2011 :  13:22:42  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by booyacht</i>
<br />Would anyone mind posting a few pictures of your running rigging on the 250? This is my first time setting it all up and I know I'm close but want to verify. I'm using the manual but it doesn't seem to list everything that I have. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I assume you already have lines up the mast and fed through the boom?
Not a very good photo but you can how the lines run through blocks at the base of the mast then through the turning blocks aft to the clutches. In the Starboard side, I have the main and (extra) jib halyard. To port, I have the single line reefing setup and an empty clutch.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I'm also concerned about the setup of the cdi furler, where exactly you run the line to roll it back up. I have it going thru the eyes to the port cam cleat. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Yep, me too, sorta. I have mine running aft to a horn cleat just forward of the midship stanchion.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Also, I appear to have an extra jib Halyard. It runs up the mast like the main halyard but empties forward. I don't know what I'd use it for since the furler has its own raising system. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> You got it, it's an extra halyard that was made redundant by CDI furler. My PO used it to fly a drifter from. I use it to secure my genoa when furled in the marina. I wrap it around the sail counter to the direction of furl. This prevents big wind from attacking the sail while I'm away. I had that phone call one already. Don't want it again. "Mr. Russell, first, your boat's alright.... you headsail, on the other hand....." I've also used it as a temporary shroud when I had one pop out of the mast last year.
Edited by - John Russell on 04/12/2011 13:36:41
booyacht
Response Posted - 04/12/2011 :  14:37:36  Show Profile
Thanks John, yes the lines are run up the mast. You have some great ideas for that spare halyard!
I'm trying to get a look at your furler, do you use a tack tension line with a few wraps between the grommet on the sail and the furler at the bottom or attach the tack directly to the downhaul shackle on the furler?
CDI's instructions say to use the tension line but the PO has everything cut to size without using it.
Response Posted - 04/12/2011 :  15:27:27  Show Profile
I actually use the tension line but, I wish the internal halyard was longer. I'm only 5'4" and the current length has me on my toes stretching to hold on while I tie it off. I think I have a solution for that but we'll see. I've been practicing bending on additional line. The truth about the shckle on the furler is that I lost on of them overboard the first time I attempted to hoist the sail so I tie off both to the same shackle.
vholmstrom
Response Posted - 04/13/2011 :  08:32:03  Show Profile
I use the "spare" jib halyard to raise my jib sock.
frog0911
Response Posted - 04/13/2011 :  18:19:39  Show Profile
Checkout this thread for ideas!
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=22963
