<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>I'll bet yours will pull the other boat backwards. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> -- Dave Bristle (from another thread)
This would mean a 4-stoke is more efficient at converting horsepower to "boat-pushing power" ("bpp" -- for lack of a better term). While this may sound off-the-wall, in order to be able to compare apples to apples, is there a better quantitative measure of true bpp than horsepower when comparing two engines, regardless of whether they're a 2-stroke or a 4-stroke or the specified horsepower? For example, could the bpp of a 9.9 hp 2-stroke be equivalent to the bpp of 6 hp 4-stroke?
Plus, I suspect there may be differences in bpp between engines of the same hp, but different years (e.g. 1990 Honda vs. 1999 Honda 8 hp, both 4-stroke). Also possibly different engine makers, props, etc.?
If so, a Tug-of-War tournament may be a good assignment for Practical Sailor.
Also, does a Tug-of-War contest test only "starting power"? How would you test "cruising power" (or is there any difference between the two)?
Hi Richard, I think that the telling difference in the horse power debate isn't in motor head, it is down at the prop. The newer 4 strokes have the same rated HP as the older 2 cycles but the newer high thrust props make all the difference. My old 15hp 2 cycle Evinrude doesn't come close to the backing power of my new 9.9hp Yamaha with a larger diameter prop. Unfortunately, the cavitation plate to prop center line distance will limit putting these larger props onto an older motor. The transom on my boat was not designed for all the torque and causes some concern and caution.
Ed Montague on 'Yahoo' 1978 #765 SK, Stnd, Dinette ~_/)~
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> The transom on my boat was not designed for all the torque and causes some concern and caution. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Ed: I think you're right to be cautious... When I put a new bracket on for our new 108# high-thrust, XLS Honda, I put a fairly large Starboard plate on the outside of the transom, and two smaller ones inside (above the shelf) to spread the load. I used two inside, rounded at the corners, because the fiberglass is more curved in there--I wanted them flat on the glass, not pressing at the corners. You can work Starboard with standard woodworking tools--I used a circular saw, orbital sander, and electric drill.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> ...the newer high thrust props make all the difference. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> I agree, and there's another innovation from the Japanese: Honda and Yamaha vent the exhaust so it comes out through the prop hub in forward gear, but foward of the prop in reverse. That way the bubbles don't get to the prop blades where they turn to foam and greatly decrease the bite in reverse.
Dave, regardless of the literature....I'm not sure the new Hondas exhaust out the prop either direction....at least not in my trash can.
And, the 90's generation Honda 8 had a lot better reverse thrust when the restricter was snapped off the shift linkage allowing more than an idle in reverse.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Dave, regardless of the literature....I'm not sure the new Hondas exhaust out the prop either direction....at least not in my trash can. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> I can't argue that--haven't run mine in a trash can. But apparently they're keeping the exhaust away from the prop. <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> And, the 90's generation Honda 8 had a lot better reverse thrust when the restricter was snapped off the shift linkage allowing more than an idle in reverse. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> My '95 throttled up pretty well in reverse, but didn't pull half as well as my '02. I doubt that the PO snapped anything off--he knew very little about boats and motors.
