 Aft plug on starboard side
booyacht
Initially Posted - 04/24/2011 :  14:24:12  Show Profile
Does anyone know what that plug is for? I lost the cap in the drink. It's about an inch and has 2 holes in it with a screw top... Just under the catbird seat. I can post a pic if necessary. Thanks!
Also when I got to the boat on Friday the marine head bowl was completely full of brown waste water. Online says to replace joker valve, anyone else have the same luck?
Apologies if this has already been discussed. iPad doesn't search this forum properly.
Will Osborn
2000 C250 WK #478
Tradewind
Response Posted - 04/24/2011 :  14:47:21  Show Profile
The plug may be a 12 volt outlet, use a voltmeter and check the holes for voltage.
If you have a marine head with a holding tank it may be full and the choker valve may be leaking causing the head to back up. If that's the case I'd empty the holding tank then try flushing the head and see if it stays clean. After emptying the holding tank and the bowl remains empty I'd replace the choker valve.
superbob
Response Posted - 04/24/2011 :  14:48:09  Show Profile  Visit superbob's Homepage
It's a vent, not a plug, for your onboard propane system that fuels the galley stove.
Response Posted - 04/24/2011 :  14:53:48  Show Profile  Visit delliottg's Homepage
Will, that cap sounds like the same one my solar panel is connected to, and if so, it wasn't a factory installed piece (or at least I don't think so). [url="http://www.sea-dog.com/groups/1992-polarized-electrical-connector"]This isn't exactly the same one as mine[/url], but should give you the idea. Mine has a screw down cap, but the connector itself doesn't screw in.
Edit: <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">It's a vent, not a plug, for your onboard propane system that fuels the galley stove.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Ours didn't come with a factory installed propane system, so I wasn't aware of this vent.
I can't comment on the joker valve, but it sounds unpleasant. You might try asking your question on [url="http://forums.sbo.sailboatowners.com/forumdisplay.php?f=31"]Peggy Hall's Head Mistress[/url] on SailboatOwners.com. She was very helpful when we were looking to replace our leaking porti-potty a while back.
If you look on the left side of the page at the bottom of the various links, there is a Google Search function that'll probably work better with your iPad than the standard forum search feature.
Edited by - delliottg on 04/24/2011 14:55:15
willy
Response Posted - 04/24/2011 :  17:34:47  Show Profile
It sounds like a plug for a Perko pole light. Why that would be on a 250 I couldn't guess but I had one on my old Beachcomber cat-rigged ketch.
Response Posted - 04/24/2011 :  18:21:44  Show Profile
I think some outboards connect to the battery that way. If your outboard does not, it might be left over from a prior outboard.
Another possibility might be a connection for a RAM mic for a VHF radio, though I'm not sure if any of them use only two wires. A more likely possibility might be a weatherproof connection for a monitor speaker or PA speaker for the radio.
Edited by - TakeFive on 04/24/2011 18:22:22
booyacht
Response Posted - 04/25/2011 :  13:00:06  Show Profile
Ah thanks! I climbed into the aft battery compartment and about a foot of cable is just hanging there snipped off from this connection. Here is an outside pic for reference. I appreciate the help!
Response Posted - 04/25/2011 :  13:08:38  Show Profile  Visit delliottg's Homepage
That looks like one of the Sea Dog connectors I linked to above. Wonder what it used to be connected to?
booyacht
Response Posted - 04/25/2011 :  13:31:32  Show Profile
You're right David. Who knows what it was used for but I guess it saves me from drilling a hole if I need to put anything 12v back there in the future! :)
Response Posted - 04/25/2011 :  15:24:02  Show Profile
I'm betting it was a connector for the alternator cable from the outboard, installed by a PO. Probably cut the wires when he/she quit using it. Could also have been used for a VHF speaker connection. Contact Perko and see if you can get a cap for it, or tape it off the keep rain water out of the leads.
Response Posted - 04/25/2011 :  16:17:56  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by booyacht</i>
<br />Ah thanks! I climbed into the aft battery compartment and about a foot of cable is just hanging there snipped off from this connection. Here is an outside pic for reference. I appreciate the help!
Not a great location, as the plug blocks visibility of the stern light.
