 Plastic oil drain plug cracked off
Initially Posted - 06/13/2011 :  19:04:20  Show Profile
Here's a heads-up for Yamaha 4-stroke owners.
So, here we are on the home stretch to launch when we resinstalled the plastic drain plug on the Yamaha 9.9 and the head cracks off . It looks like I'll be able to back out the stem with an easy-out.
I assume it became brittle with age . . . it's a 1997 model.
Response Posted - 06/13/2011 :  20:12:02  Show Profile
Plastic plugs suggests that they believe you should buy a new motor every 10 years.
Response Posted - 06/14/2011 :  02:40:39  Show Profile
<br />Plastic plugs suggests that they believe you should buy a new motor every 10 years.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I'm gonna run that one past the admiral!
Response Posted - 06/14/2011 :  04:24:57  Show Profile
Sounds more like they had problems with corrosion or people crossing threads. Plastic might be a good solution, but ya gotta get a new plug every 7 years. I've got a water pump running slow ( or drain clogged ) on my 84 outboard, so I guess I'll try to get the '74 running and change them out and work on the '84. It would be fun to get the '56ish running, but that is probably not worth the trouble.
We just fired up the '94ish 225hp and it ran good after sittin up for about 2 years ... skippin some on idle so I might change out the plug wires.
Or we might just run it....
Response Posted - 06/14/2011 :  16:47:47  Show Profile
Yamaha outboard dealers are non-existent in Pittsburgh. The local dealer stopped carrying Yamaha products. You would think with our 3 rivers there would be adequate demand. I called two dealers that are 20+ miles away and I felt like I was imposing upon them when I asked if they would mail a replacement drain plug. I guess I'll deal with an internet supplier instead. So much for buying local.
Life sure would be a lot easier if Yamaha had just used a metal plug!
