 easy lock clutches- rebuild or buy new?
Alan Clark
Initially Posted - 06/24/2011 :  11:48:02  Show Profile
The Easy Lock Clutches on "Leprechaun" have grooves worn on the rollers in the clutch and I would rather re-build/replace the rollers than buy new clutches - We have done enough of rebuilding the economy this year -(New 9.9 Yamaha high thrust electric start long shaft). Has anyone else had the same issue- new Easy Lock clutch doubles are $149.00 each and would probably NOT fit the same holes in the coach roof (Filling and drilling) AGAIN . Any other information would be great.. Thanks again..
Alan & Eileen
2001 Catalina 310 Hull #155
"Anam Cara"
ex-1987 C25 TR/SK #5612
"LEPRECHAUN"
Troy Ohio USA / Lake Erie-Catawba Island
ASA 101 103 104
"The clink of an anchor - chain, the 'Yo-Ho!' of a well time crew, the flapping of huge sails - I love all these sounds."
John 'Rob Roy' MacGregor
Response Posted - 06/24/2011 :  13:09:46  Show Profile
Maybe I'm missing your point . . . rope clutches are pretty simple devices and parts are available
http://www.rigrite.com/hardware/rope_clutches/Easylock_Handles.html
Perhaps there are rivets you are unsure how to remove and replace?
Have you Googled these words? "easylock clutches parts & service"
Edited by - OJ on 06/24/2011 13:10:57
Alan Clark
Response Posted - 06/24/2011 :  13:35:11  Show Profile
That was what showed up when I googled it, I also called PYACHT and spoke with their technical dept. He was going to call me back to let me know IF parts are available, as in the rig-rite ad, I think mine (as is my luck) are the ones that parts are NOT available..
I have no idea of age but they Look older.. The tech guy has not called me..it is friday though.. , I am thinking ebay is the way to go for a double clutch and again filling and drilling ..thanks for your response.
Stu Jackson C34
Response Posted - 06/26/2011 :  16:45:11  Show Profile
Depending on the placement of your original clutches/sheetstoppers, you may only have to drill ONE new hole. That'd be only half the work.
Alan Clark
Response Posted - 06/26/2011 :  19:07:27  Show Profile
Better One Hole than three I guess.. still waiting to hear from Rig Rite.......
