Need quick help-- Does anyone know the size and thread of the bolt that holds the rudder to the tiller arm. It's located on the end of the tiller arm where the rudder is attached to the tiller arm
Jack Schafer, previous owner of 2ndWind 250WB #106,
They are a 1/4 inch, you can order them at the below address. when you replace them make sure sure the connection is turning, it will help reduce the tension.
THanks for the reply, That is not the part I was looking for. I have the old push-pull system that edson dropped when they came up with a wired pull-pull. I did find the proper bolt and it is a 3/8 bolt. I did convert the system to a pull-pull by duplicating the original on the port side and a small mod of the chain, Has worked great for the last 8 years.
