 Mechanical hatch lift
rrick
Initially Posted - 09/13/2011 :  19:14:05  Show Profile
I inherited one of these that gives 12' extension and ~400lbs force. Any ideas? It was a bit short for my pop-top and a little slow for an autopilot and does not stay locked for a boom vang. It is for marine applications and has 1/4 the value on the used market.
Molly Brown: 1967 Grand Banks 32-#34. Bronze, mahogany, teak, oak, with 120hp diesel to push all 10 tons. Currently an abuser of the bilge pump. Also... The Tall Rig Spirit: 1978, #973, Cast Fe Fin Keel on a Trailer
Edited by - rrick on 09/13/2011 19:16:24
Response Posted - 09/13/2011 :  21:01:04  Show Profile
Looks like a lift for an engine hatch on a power boat.
Response Posted - 09/14/2011 :  08:22:45  Show Profile
Is that cable an electrical connection or what?
rrick
Response Posted - 09/14/2011 :  10:23:22  Show Profile
"lift for an engine hatch on a power boat" . Resale vs an electromechanical aluminum housed sealed wire stainless ram doesn't add up. Touch leads once it extends, again it retracts. Perfect for the pop-top if it was the longer version.
Response Posted - 09/14/2011 :  12:07:39  Show Profile  Visit Prospector's Homepage
Can you control how much it extends/retracts? Looks like a key component for a power-steering linkage to teh outboard.
Or as one of my old bosses would say "A solutuion looking for a problem"
Response Posted - 09/14/2011 :  12:11:38  Show Profile
Sounds like a great opportunity for installing that as one arm in a linkage system for the pop-top.
rrick
Response Posted - 09/14/2011 :  15:08:42  Show Profile
It would be almost grand for two new lifts at the right length to balance both pop-top sides, and of course be even more a source of envy if you got the model that locked at extension. This one pushes under an inch a second and releases force without electricity applied, so no steering use, was the base model (still like $500). The pop-top gas struts are going on now and this lift is still headed to that purpose.
Response Posted - 09/14/2011 :  15:15:38  Show Profile
RRIck,
Did some quick figures, and tried looking up specs: The struts are 12 1/2" long? If you can mount the mechanical lift at a point 8 1/8" from the hinge point, the chord length is your 12" extension......using 95° as rotation angle of the pop top struts.....perhaps with the gas struts, lifting on one corner will be possible, otherwise try a releasable connection in the center of the top (forward or aft edge)to be hooked up when you want to raise and stowed away when not needed.
Edited by - Ape-X on 09/15/2011 03:32:36
