 What does this do?
JimGo
Initially Posted - 10/25/2011 :  08:35:41  Show Profile
I was out on the boat this weekend, but didn't remember to snap a picture I wanted. However, in looking at another thread over on Sailnet, I happened to see this picture, and it jogged my memory:
See the block and cleat on the boom? What do they do? I originally thought they were for an outhaul, but the block is oriented in the wrong direction.
I have a few other connectors and "things" hanging on my boom as well, and I'm trying to figure out why they are there. They are hard to see (since I haven't taken a specific picture of them), but you can make out most of them in the various photos in my [url="http://bit.ly/sm9coF"]Photobucket album[/url]. Here's probably the best shot of the bunch:
Are the "eyes" along starboard side the boom for reefing? How about the one that's underneath the boom?
Thanks in advance for any feedback!
- Jim
Formerly of 1984 C25 named Dragon Wing
NOTE: In my case, PLEASE don't confuse stars/number of posts with actual knowledge. On any topic.
Edited by - JimGo on 10/25/2011 08:51:34
Response Posted - 10/25/2011 :  08:44:59  Show Profile
Image is a broken link.
JimGo
Response Posted - 10/25/2011 :  08:46:12  Show Profile
OK, that should be fixed now, and I've updated my question a bit.
Edited by - JimGo on 10/25/2011 08:52:17
Response Posted - 10/25/2011 :  09:23:34  Show Profile  Visit OLarryR's Homepage
Jim,
maybe this sketch will help. On the right of the Forum is a link for manuals. The post '88 manual has more sketches than the pre-'88 manual and so I copied the sketch from the post '88 manual.
JimGo
Response Posted - 10/25/2011 :  09:37:27  Show Profile
Aha! Thanks Larry! Now that makes more sense.
And I appreciate your subtelty in telling me to "RTFM"! :)
Response Posted - 10/25/2011 :  09:49:44  Show Profile
That top picture is what I'd be inclined to call a cluster-f#%k. Just about <i>nothing</i> is right there.
JimGo
Response Posted - 10/25/2011 :  10:04:45  Show Profile
Dave, I was only looking at the block and cleat; wasn't relying on them for an actual "appropraite" configuration! I saw that I thought were lazy jacks on there, but the rear set looks really confusing, so I decided to not pay any attention to them.
Larry's picture brings up an interesting issue for me. The cleat that's in the mast track above the pop-top catch is so low that the pop-top catch can't get up high enough to catch the pop-top. I assume I can move the cleat up by loostening the two screws there; is that correct?
I think I remember seeing a "what size lines for reefing" thred a few days ago; I'll have to go back and re-read that to make sure I get the appropriate lines. I'll have to read the manual too to figure out whether those reefing lines can stay attached, or if I'm supposed to remove them when the sail isn't reefed.
Response Posted - 10/25/2011 :  10:25:14  Show Profile
The reefing lines can remain in place, slightly slack, ready for action. The drawing is of a two-line system (which I prefer). With another cheek block forward on the boom, it can be a single, continuous line, which others prefer. (I like to tension the tack before the clew, to prevent pulling slugs out of the mast.)
Either one or two lines can be led from the mast back to cabintop clutches, along with the main halyard, so the whole job can be done from the cockpit. A "tack hook" at the gooseneck is an effective alternative to the line through the tack, but then you <i>have</i> to go to the mast to reef. There are lots of options...
JimGo
Response Posted - 10/25/2011 :  12:14:49  Show Profile
Thanks Dave!
Response Posted - 10/25/2011 :  12:18:52  Show Profile
Looking at the diagram I see a forward cheek block on the boom wouldn't pull the tack down <i>and foward</i>. I wonder if mounting a block on the mast would work. I will be taking the line back to the cockpit.
Response Posted - 10/25/2011 :  12:27:08  Show Profile
OJ, for single-line, I'd put a cheek block on the mast--for just that reason.
Edited by - Stinkpotter on 10/25/2011 12:28:51
JimGo
Response Posted - 10/25/2011 :  12:29:04  Show Profile
Ray, are you talking about the 2nd picture? I swear I rotated that stupid picture!
Response Posted - 10/25/2011 :  12:38:41  Show Profile
Yepper .. I had to delete that post. Everybody needs to be able to post images for help without my ridicule.
Anyhoo.. yepper you got an interesting setup there. There are a million ways to rig a sailboat.
JimGo
Response Posted - 10/25/2011 :  13:22:14  Show Profile
Ray, I am fairly thick skinned - ridcule, especially good natured, is OK with me.
OJ, I am thinking of putting in a single line reefing system; I'd love to see what you come up with.
Here's the reefing line discussion: http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=24080
Edited by - JimGo on 10/25/2011 13:23:38
Response Posted - 10/25/2011 :  13:36:54  Show Profile
Jim,
Your signature says you have a standard rig, but your boom seems a bit low for one. Also, your boom vang appears to have too much angle, but again that could just be an optical illusion.
JimGo
Response Posted - 10/25/2011 :  14:00:59  Show Profile
Don,
The guys who sold me the boat said that they lowered the boom "because it made the boat faster". It should be higher, and will be in its proper place next season. I think the real problem was that the wire halyard stretched and the transition between the wire and rope would get caught on some of the rigging, so they just lowered the boom. I have a handful of "tweaks" I want to make to the boat during the winter, including:
1) Adding a solar-powered fan for ventilation;
2) Adding cam cleats for the jib sheets (the Admiral has already OK'd this, as it's what she's familiar with, too);
3) Switching to all-rope halyards;
4) A thorough inspection of the hull below the waterline;
5) Checking the electrical systems;
6) Painting the bottom;
7) Sanding and refinishing the topside teak;
8) Testing for leaks and fixing any that I find; and,
9) Patching the spiderwebs in some of the gelcoat.
You'll notice that the all-rope halyard are pretty high on the list, and the low boom is the primary reason for this.
Response Posted - 10/25/2011 :  14:07:41  Show Profile
Don makes an interesting point. Is the mainsail raised to the top of the mast? If it is, methinks you have a tall rig.
Response Posted - 10/25/2011 :  15:27:51  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JimGo</i>
<br />3) Switching to all-rope halyards<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">You may be aware that you'll need new mast-head sheaves for them. (Your originals are likely to be sun-damaged anyway.)
JimGo
Response Posted - 10/25/2011 :  16:08:44  Show Profile
Dave,
Thanks for the warning. I did see that, although I still need to learn what a sheave I
Why do you guys always ask me measurement-related questions on Mondays and Tuesdays?
Response Posted - 10/25/2011 :  17:39:48  Show Profile
<br />Why do you guys always ask me measurement-related questions on Mondays and Tuesdays?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yep, Mondays and Tuesdays are always more quantitative . . . rest of the week is just qualitative.
Response Posted - 10/25/2011 :  17:41:31  Show Profile
More ideas:
http://www.harken.com/rigtips/MainsailReefing.php
JimGo
Response Posted - 10/25/2011 :  18:11:59  Show Profile
LOL - Thanks for that clarification! It seems like I get back from the boat and there's alway some thread that comes up the next day or two where I think "wow, if I had only measured..." or "if I had only taken a picture of...".
Response Posted - 10/25/2011 :  21:23:41  Show Profile
Switching to all rope halyards will require dropping the mast. The masthead sheaves, the rollers at the top of the mast (there are 4 of them) will have to be replaced with wider ones to handle the wider diameter of rope vs. the old wire. It's an easy swap out but the sheaves are not inexpensive, around $12 each. With a standard rig, 75' of 5/16" line should be adequate for each halyard. Actually, if you want to get more precise, 70' would likely work for the main halyard (2 x 28' length of mast = 56' plus 10' to run back to the cockpit = 66' rounded up to 70). The same can be done with the jib halyard, i.e. length of mast plus forestay plus 10 rounded up.
JimGo
Response Posted - 10/25/2011 :  21:38:14  Show Profile
Thanks David! That's basically what I needed to know. I want to put together my Christmas list. The mast has to come down anyway, so it's a good time to do all of these things.
Response Posted - 10/26/2011 :  07:41:01  Show Profile
<br />The same can be done with the jib halyard...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...although with roller furling, just leave the halyard cleated on the mast all season (and skip the extra 10')
Response Posted - 10/26/2011 :  09:29:57  Show Profile
Good point, Dave! also, while the mast is down, you may want to replace the lens/light at the masthead. Odds are the lens is heavily crazed.
