 Chocks
NautiC25
Initially Posted - 02/20/2012 :  19:13:56  Show Profile
I stole this pic from Ryan's post. I was wondering where you can get both sizes of wall-mount chocks? All the ones I find are for the mast and deck.
1989 C-25 TR/WK #5894
Miss Behavin'
Sittin' in LCYC on Canyon Lake, Texas
Response Posted - 02/20/2012 :  19:21:47  Show Profile
I bought mine at WM in two sizes. One boathook clips horizontally above the starboard settee and one is vertical beside the companionway.
NautiC25
Response Posted - 02/20/2012 :  19:48:22  Show Profile
I've been all over WM and Defenders site and don't see them. Our local WM is pathetic, so I doubt they're in the store.
Response Posted - 02/20/2012 :  20:01:38  Show Profile
Go to your local hardware store and find some broom/mop holders.
Response Posted - 02/21/2012 :  07:38:22  Show Profile  Visit aeckhart's Homepage
I cut two four inch long pieces of PVC pipe that had the same inside diameter as the outside diameter of my wisker pole, and cut a slot in each piece to allow the pole to snap into this "fitting". I beveled the edges to allow the PVC to more readily accept the pole. The PVC body is thick enough to accept a beveled screw hole and rounded screw head so it will not mar your pole. It's lasted for about seven years without failure.
I suspect you can use smaller diameter PVC pipe for your boat hook as well.
NautiC25
Response Posted - 02/21/2012 :  08:01:01  Show Profile
Thanks. That may be the route I take since I'm still not finding them on the WM site. Ryan also says he got them at WM. Arg! I guess I can stop by the store just in case.
Response Posted - 02/21/2012 :  08:28:00  Show Profile
New Defender catalog arrived last week. See page 151, right side of the page: Beckson Plastic Clipper Holding Clips, 5 sizes.
Response Posted - 02/21/2012 :  08:52:42  Show Profile
I can't find them on the WM site now, just the expensive stainless ones. I'll look at mine later today and see if I can find a brand/part number. I did find some on the Perko site.
Ryan L
Response Posted - 02/21/2012 :  09:16:45  Show Profile  Visit Ryan L's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by NautiC25</i>
<br />Thanks. That may be the route I take since I'm still not finding them on the WM site. Ryan also says he got them at WM. Arg! I guess I can stop by the store just in case.
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=43982& catalogId=10001& langId=-1& storeId=11151& storeNum=50304& subdeptNum=50340& classNum=50342
NautiC25
Response Posted - 02/21/2012 :  09:34:18  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Ryan L</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by NautiC25</i>
OMG, thanks! "Holding clips" I tried entering pole chocks, chock, pole mount, wall mount, mount, pole clips, pole holder.....
Ryan L
Response Posted - 02/21/2012 :  09:43:35  Show Profile  Visit Ryan L's Homepage
If you're looking for a "pole holder" you want a different website... ;)
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Ryan L</i>
Response Posted - 02/21/2012 :  10:39:36  Show Profile
Halleluia, there were no identifiers on mine, but that looks like the answer. Maybe search engines will move toward and improve upon the Siri model and try to interpret your words to find what you're actually looking for.
NautiC25
Response Posted - 02/21/2012 :  10:47:33  Show Profile
lol, yea they need to read my mind!
And what are they doing in the "fender accessories" section anyways?
Edited by - NautiC25 on 02/21/2012 10:56:58
Response Posted - 02/22/2012 :  13:20:45  Show Profile
I cut a hole in the face of the quarterberth to stick one end of the pole in, then mounted a deck chock on the face of the settee for the other end to lock onto.
Response Posted - 02/22/2012 :  13:25:17  Show Profile
I just store mine in the dumpster. It's out of the way when I don't need it and can be retrieved without taking my hand off the tiller.
NautiC25
Response Posted - 02/22/2012 :  13:47:45  Show Profile
<br />I cut a hole in the face of the quarterberth to stick one end of the pole in, then mounted a deck chock on the face of the settee for the other end to lock onto.
Yea, I saw the pic in the tech tips. But, I have my solar charger and other electrical stuff there. (Battery box in the way too?) And those deck chocks are like $50 each. lol
I got the pair of clips on order at my local WM and they say they should arrive by friday just before I head out to the boat. :)
<br />I just store mine in the dumpster. It's out of the way when I don't need it and can be retrieved without taking my hand off the tiller.
You're just talking about your boat hook right? I don't think the 7' whisker pole would fit.
Response Posted - 02/22/2012 :  13:55:25  Show Profile
Yeah, just the boat hook. Frank's solution for the pole is pretty good.
Response Posted - 02/23/2012 :  13:24:49  Show Profile
I just store mine on the cabin top with the hook-end slid outward through a hole under the teak handrail, and the shaft lying flat between the hand rail and the jib halyard. Never seems to move around, and is always handy.
Response Posted - 02/23/2012 :  14:19:37  Show Profile
Response Posted - 02/23/2012 :  15:01:58  Show Profile
Well done Don!
davidbloodworth
Response Posted - 02/25/2012 :  10:00:02  Show Profile
I chose to store my whisker pole at the bottom of Alan Henry Lake!!
Response Posted - 02/25/2012 :  10:55:50  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by davidbloodworth</i>
<br />I chose to store my whisker pole at the bottom of Alan Henry Lake!!
Some of those clips look like they could also be used to store rolled-up nav charts, perhaps under the quarter berth.
Response Posted - 02/25/2012 :  13:43:42  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I chose to store my whisker pole at the bottom of Alan Henry Lake!!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
It might not be handy, but at least you know where it is.
Response Posted - 02/25/2012 :  16:58:09  Show Profile
LOL...I wonder if you take the tubes apart and fill them with some foam insulation spray ( in cans from HD or the like) Use the kind that expands the least. Put a wad of paper in the tube first to stop the foam from getting near any buttons. You could do this in the smallest tube so the foam won't interfere when you collapse it. Do you think it might float then?
NautiC25
Response Posted - 02/27/2012 :  07:48:38  Show Profile
Well, I bought the 2" clips for the Forespar and they worked great! Thanks again Ryan for pointing me in the right direction.
Ryan L
Response Posted - 02/27/2012 :  19:07:42  Show Profile  Visit Ryan L's Homepage
Glad they worked for you!
<br />Well, I bought the 2" clips for the Forespar and they worked great! Thanks again Ryan for pointing me in the right direction.
