 Installing through the hull transducer
tomh
Initially Posted - 03/18/2012 :  18:16:20  Show Profile
Guys,
I know that I've seen discussions about installing transducers but I can't find any now that I have one to install.
Can anyone offer any suggestions?
Tom
1978 C25 "Karma" #790
Toledo Beach Marina
LaSalle, Michigan
Response Posted - 03/18/2012 :  18:40:20  Show Profile
Depth transducer? Try this link or search "transducer mounting" http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=16708
tomh
Response Posted - 03/19/2012 :  03:09:10  Show Profile
Thanks Dave.
hewebb
Response Posted - 03/19/2012 :  03:35:08  Show Profile
I just installed a speed indicator thru the hull. I drilled the hole and used 3M 5200 sealant in black. I cleaned the surfaces with acetone and isopropyl alcohol. I also did a test set up with the plug with two old pieces of wood-I cannot break them apart. It did take several days to cure.
tomh
Response Posted - 03/19/2012 :  04:12:33  Show Profile
This will be a depth transducer for a Garmin. I like the wax ring idea a lot. It looks like the best place to locate it is on the center line of the hull at the aft end of the V berth.
Response Posted - 03/19/2012 :  07:50:05  Show Profile
The wax ring idea works very well. I placed ours close to centerline just behind the swing keel trunk, making it very east to wire up.
