 Tohatsu 9.8/Nissan 9.8 Impeller change
Initially Posted - 03/27/2012 :  03:00:09  Show Profile  Visit britinusa's Homepage
Anyone changed their Tohatsu/Nissan impeller?
Looking for supplies and method.
Our engine is 5 years old, strong jet of water from the impreller, but seeing recommendations to change it.
FYI, I flush the engine with fresh water after every haulout=after every trip.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 03/27/2012 :  06:06:57  Show Profile  Visit DaveR's Homepage
Sounds like you're good but I've heard for a long time that replacing the impeller every 3 years or so is recommended. I personally just go with the flow (pun intended) and change it out when it looks like it needs it. As far as methods and supplies I have nothing to add except the obvious, ask the question in a general search of the internet and also on youtube.
Response Posted - 03/27/2012 :  07:20:37  Show Profile
I tried to find an online reference but could not. This is from the service manual I have:
<i>1) Remove the spring from the shift rod joint with the spring pin tool.
2) Remove the four (4) gear case bolts and then pull the gear case assembly.
3) Remove the three (3) pump case bolts and then pull the pump case (with the liner).
4) Remove the pump impeller and replace with a new one.
Note:
Beside the impeller, inspect the guide plate and liner also. If they are badly worn, replace them.</i>
I have not replaced my impeller yet, the motor is four years old, the water stream still looks strong.
Response Posted - 03/28/2012 :  20:04:21  Show Profile
As long as you have a strong water stream, don't worry about it. However, it's a good idea to have the parts on hand for when the time does come to change the impeller. Try these guys:
http://www.boats.net/parts/search/parts.html?gclid=CPmrv6qPi68CFcqe7QodJGCg_A
Also, regarding the Nissan 9.8, it's a good idea to have on hand a backup set of bracket nuts, part #29 in the diagram below. Both of mine vibrated loose completely not too long after I bought it:
http://www.boats.net/parts/search/Nissan/Outboard/2008/NSF9.8A3/BRACKET%20%28FOR%20%22MF%20%26%20EF%22%20TYPE%29/parts.html
Edited by - dmpilc on 03/28/2012 20:08:13
Response Posted - 03/29/2012 :  03:43:32  Show Profile  Visit britinusa's Homepage
Thanks David,
that bracket nut issue must have been dramatic
I found the page on boats.net that shows the impeller diagram. Very helpful, I'll contact them and order the parts.
Agreed! Better to have the bits on hand to prevent delay if the stream does weaken. But so far the engine has performed great. It is time for a carb cleanout though.
Response Posted - 03/29/2012 :  07:32:22  Show Profile
Order the low idle jet and replace it when you tear down the carb. That's the only way to get to it, and it clogs up very easily.
Regarding the bracket nuts, fortunately, I noticed something odd about the way the motor was running, idled back, and limped back into the slip. It could have been a disaster.
You can reach your hand back there around the housing just barely to check them, and I recommend doing it regularly. They should not feel loose. If one of the nuts does come off completely, the plastic housing around the shaft should catch it. Be careful removing the housing, and you should be able to retrieve the nut.
Edited by - dmpilc on 03/29/2012 07:42:04
Response Posted - 09/01/2012 :  12:52:36  Show Profile  Visit delliottg's Homepage
Paul,
Did you ever do your impeller replacement? I noticed that ours isn't peeing as well as it should last time we were out, so I want to do the swap. I already have the kit, I'm just wondering if I can do the swap while the boat's in the water?
My plan is to back the boat into it's slip so the OB is over the dock. Does anyone know if this is viable? I really don't want to have to remove the engine to do this.
Any gotchas while doing this?
