 Seizing shrouds to spreaders
Initially Posted - 05/18/2012 :  06:06:36  Show Profile  Visit Prospector's Homepage
OK, I'm a bad boatowner. After 5 years of sailing bliss, I am finally getting around to replacing my spreader boots. I know this is supposed to be done with higher frequency, but meh.
When I took the old boots off, I was surprised to find that the seizing wire that holds the shrouds in the grooves of the caps on the ends of the spreaders had rusted away to almost nothing.
I would look up how to sieze the shrouds in one of my many sailing books, but alas, they are all packed since we are getting ready to move.
Does anyone know of a good diagram online showing how to sieze the shrouds, and what material to use - was carbon steel preferred for its softness? Is Stainless too brittle for this application? Is aluminium out of the question?
Your tips are welcome and appreciated!
"Iris"
1984 FK/SR #4040
Response Posted - 05/18/2012 :  06:23:16  Show Profile
Response Posted - 05/18/2012 :  06:30:55  Show Profile
The boots should come off without need to take off the seizing wire. I have my shrouds in the garage currently, along with the boots. I plan to use rigging tape then to wrap the boot to the shroud and spreader.
Response Posted - 05/18/2012 :  06:49:12  Show Profile  Visit Prospector's Homepage
Yanno Don, I should know to look in the manuals section by now. Thanks and sorry for taking your time.
Response Posted - 05/18/2012 :  06:51:26  Show Profile  Visit Prospector's Homepage
Yeah Ape-x, the boots do, but the wire was badly corroded (rusted) and came off with the boots - no choice but for a redo. Now I need to locate some stainless wire. While I'm at the chandlery, I may as well get new cotterpins for the spreader to mast connection. Anyone got a size for them, they aren't detailed in Don's pic above.
Wait - lemme go check the manuals first...
Edited by - Prospector on 05/18/2012 06:55:25
Response Posted - 05/18/2012 :  06:59:18  Show Profile  Visit Prospector's Homepage
Got it!! http://www.catalina-capri-25s.org/manbro/pictures/pc15.gif
Its interesting that in this image the seizing looks different than in the one Don posted above,I wonder if there were 2 options there.
Response Posted - 05/18/2012 :  11:57:04  Show Profile
CD sells the seizing wire, Stainless. It's easy to do. The trick is to end up so that the shroud won't jump out of the groove in the end cap and the seizing wire loops that go around the shroud are just loose enough that the shroud can slide through the loops.If the loops are to tight you will pull your spreaders down when you go to tighten up the turnbuckles. TIP, Put a toothpick or a small brad against the shroud then wrap the seizing wire around the shroud and the toothpick then just remove the toothpick. The loop will be loose enough then. If your old wire was rusted I would guess that someone replaced the factory stainless wire with some regular steel wire. When I replaced all my standing rigging last year, The original wire was perfectly good, No rust but I put new wire on because I had ordered it. I have plenty left over if you want to come and get it
Edited by - islander on 05/18/2012 12:15:50
Response Posted - 05/18/2012 :  12:10:16  Show Profile  Visit Prospector's Homepage
Thanks for the offer Scott. I ran to te chandlery at lunch and got some wire (stainless) but they had 2 gauges of it. I got the heavier gauge, (0.032") but it was a WAG which size I needed. If yours is nearby and marked with a gauge size, it would be helpful to know what size it is.
Response Posted - 05/18/2012 :  12:21:06  Show Profile
Yep, It's .041. I just edited my previous post to include a tip on making the loops if you want to re- read it
Response Posted - 05/18/2012 :  13:01:24  Show Profile  Visit Prospector's Homepage
Thanks Scott for the tip and te gauge size. Now when I get home I'll have to have some appetizers so that there will be toothpicks available.
Response Posted - 05/18/2012 :  17:41:56  Show Profile
Mine has a hole for a cotter pin through the end cap and holes in the end cap for seizing. That makes it easy to keep the seizing loose enough for the shroud to move but stay trapped to the spreader tip. I use monel instead of SS.
Edited by - Dave5041 on 05/18/2012 17:43:42
