 outside teak
markolito
Italy
Initially Posted - 01/12/2003 :  17:48:33  Show Profile
quick question about the outside teak..
my freind and i are wondering what the best product to apply on the outside teak is. I am in favor of using cetol for all the outside teak, hatch doors, and tiller. Even though the color is not the best it is durable. He insists on using teak oil.
thanks
Response Posted - 01/12/2003 :  18:10:44  Show Profile
Marco - we've had many a discussion about the outside teak...the consensus is to go with Cetol. The problem with oils is that they deteriorate in sunlight and even mildew (yech!). Cetol, even in the hot S.Texas summer, will last almost 2 years. For the tiller I personally used 3 coats of polyurethane to allow the laminations to show the grain - it looks beautiful.
Derek
Mark Loyacano
Response Posted - 01/12/2003 :  18:18:19  Show Profile
I used Cetol "Light". No off color problems with that. The big job was belt sanding and prep work before applying it. Worth the effort. I did all the exterior teak including new teak hatch boards purchased from Catalina Direct.
markolito
Italy
Response Posted - 01/12/2003 :  18:38:37  Show Profile
thanks alot for your quick responses
Response Posted - 01/13/2003 :  10:12:05  Show Profile
I use Sikkens Cetol Marine... it comes in a couple 'flavors'... the original dark finish, a lighter finish, and a satin finish.
The material 'builds' with multiple coats and can be easily 'retouched' by dipping synthetic steel wool in the cetol and applying some elbow grease. Beats sanding anyday.
I have been completely pleased with the results.
'78 Catalina 25
markolito
Italy
Response Posted - 01/13/2003 :  15:06:58  Show Profile
i went out and bought the cetol but i got the "gloss" one because i want to keep the color of the wood just the way it is... is this different than the light one mentioned above? or is it simply color..
Response Posted - 01/13/2003 :  16:17:36  Show Profile
I haven't used the 'light' one myself yet... so I unfortunately, can't comment on it directly.
I can say that the original 'gloss' Sikkens gives a slight brown... say... maple syrup...coloration.
I think if you have nice figure in your teak and it's in good shape, the lighter one might be very pleasing... however, for the "well-aged" (vintage?) teak on my current project boat, the darker color hides a lot of the defects.
'78 Catalina 25
Response Posted - 01/13/2003 :  19:58:21  Show Profile
I like Cetol.
<img src="http://im1.shutterfly.com/procserv/47b3df32b3127cce93e75e65db4b0000001410" border=0>
<img src="http://im1.shutterfly.com/procserv/47b3df32b3127cce93e77ec9dbf70000001410" border=0>
Don Lucier, 'North Star'
C25 SR/FK
Cradled on the hard, 200ft from Lake Erie
Buzz Maring
Response Posted - 01/15/2003 :  11:54:06  Show Profile
<font color=blue>The material 'builds' with multiple coats and can be easily 'retouched' by dipping synthetic steel wool in the cetol and applying some elbow grease. Beats sanding anyday. - ClamBeach</font id=blue>
Hi Clam,
That sounds like a great idea ... but what is "synthetic steel wool" ... ?
jwilliams
Response Posted - 01/15/2003 :  12:12:20  Show Profile
Hi all,
There's always a contrarian...I used Armada with excellent results. It doesn't orange and I have had to recoat only once in three years.
You use a 3M purple pad to "tooth" the surface, followed by an acetone wipe-down. Easy.
The color of the stuff in the can is like "baby poop", but it goes on clear and stays tuff.
For the first treatment:
Good prep. The first coat takes about 48 hours to dry. You do not sand or rough up for the next two coats. They take about 8 hours to dry.
Jim Williams
Hey Jude C25fk 2958
Half Moon Bay, CA
Response Posted - 01/15/2003 :  19:44:55  Show Profile
"Synthetic Steel Wool" is a synthetic scrubbing/finishing pad made by 3M... the consistency is somewhat similar to a brillo pad... or other synthetic pads on the market.
Each sheet is perforated so you can easily seperate a little chunk.. about 1-1/2" x 4"... which are just the right size for refinishing in tight areas.
When used in combination with the cetol you are basically smoothing out the old finish and put on new material at the same time.
It leaves a nice classic 'burnished' appearance.
'78 Catalina 25
