 Sealing newer style windows
Ben
Initially Posted - 06/17/2012 :  06:03:49  Show Profile
Hi all,
I have an 87 C25, and it has the style windows without the metal frames on the exterior. My windows leak, like those of a lot of boats. I've tried removing the windows to reseal them, but they're glued in pretty well. Can I just take a bead of caulk around the outside edges of the windows where they meet the gelcoat? I don't know much about silicon caulk and don't know if it's appropriate for exterior use, or if there's a better material to use, like 3200, or 4000?
Ben
Beneteau 361
Viking Kitty
Columbus, Ohio
Response Posted - 06/17/2012 :  06:12:39  Show Profile
Here is my battle with the '87 windows:
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=23031& SearchTerms=new,windows
I had some temporary success prior to that using "flow-able windshield sealant" found in auto parts stores. But replacing and resealing the windows has stopped all leaks.
Response Posted - 06/17/2012 :  12:19:26  Show Profile
Davy, nice work. I am needing to do this same project. I have a couple of questions.
Did a lot of the 795 squeeze out around the inside and outside edges when you pushed the windows into place?
What did you use as the sealant for the final treatment around the installed windows - 795 or something else?
Thanks. Glad to see that the result can be so good looking.
Response Posted - 06/17/2012 :  14:53:14  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Did a lot of the 795 squeeze out around the inside and outside edges when you pushed the windows into place?
What did you use as the sealant for the final treatment around the installed windows - 795 or something else?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
A little bit squeezed out on the inside, not much on the outside. However, I think this will depend on how big of a bead you apply.
Dow Corning 795 was used between the fiberglass and the acrylic and the final bead around the outside of the windows. After a bit of research, I think this is what the Catalina factory does on newer boats.
Response Posted - 06/17/2012 :  18:14:40  Show Profile
Thanks. I was trying to figure out if they really lay on the 795, let it squeeze out and then smooth it out then as the final touch or first get the window adhered and then do a bead around the edge afterwards.
Response Posted - 06/18/2012 :  05:02:19  Show Profile
If you look at the original thread, I taped off the windows, then I applied a bead, squeegeed this down, removed the tape, applied another bead, I think it was about 3/16" to a 1/4". Then pushed the windows into place. The next day I applied a small bead around the outside and smoothed into place.
I noticed at the boat shows, that on new Catalinas, the outside bead is fairly wide. So when I cut new windows, I cut them slightly smaller so that there would be a larger bead of sealant around the outside.
