 Lowering swing keel on C-25
Scribby48
Initially Posted - 07/03/2012 :  07:18:14  Show Profile
I just bought a Catalina 25 and would like to know how I tell when the keel is fully lowered. Also, is it possible to lower it too far? Thanks for any advice.
Response Posted - 07/03/2012 :  07:32:11  Show Profile
Congrat's on the purchase of your C25. Welcome aboard!
As to lowering your keel, no, you can't lower the keel too far as it is physically impossible to do so(keel head hits the trunk as shown below), but you don't want to slacken the cable on the winch. On my old swinger (not a C25), I'd just lower the keel until the cable went just slack, then I put tension back on the cable. After a while, you'll figure out how many cranks it takes to raise and lower the keel.
Response Posted - 07/03/2012 :  07:35:22  Show Profile
Welcome Scribby! I'll let the swingers answer that, but meanwhile I'll suggest that you:
1. Join the association--it's one of the best sailing communities on the web.
2. Check out Catalina Direct and consider buying their C-25 Owners' Handbook. They're a 3rd party outfit that knows our boats and has lots of good stuff for them.
3. Set up a "Signature" under "Profile" (above), showing your hull number, vintage, keel, rig, and sailing location. It'll help us give better answers to many questions.
4. Ask away! No question is "dumb" here.
Enjoy your swinger!
Response Posted - 07/03/2012 :  07:54:02  Show Profile
The cable will go slack when the keel is fully lowered. On my boat it takes thirty-two cranks to raise or lower. Contrary to the advice on the forum, I sail with the cable slack. I hate the humming noise that the tight cable produces when you get the boat up to speed.
Response Posted - 07/03/2012 :  08:25:32  Show Profile
Don's got it - all the way out and a 2-3 turns back for tension. The cable hums at around 3 to 4 knots. It isn't a critical number, but too loose lets the cable move and flex too much; it also means that if you hit something hard, like a rock, the keel could swing up and bang against the keel trunk when it swings back down. Not a good thing! Having too tight will progressively increase load on the cable and move the center of resistance aft. If you haven't already, search the forum for a lot of threads that discuss important issues about examining and maintaining the swinger. And finally, Welcome Aboard! We'll answer your questions either way, but the organization is the best $20 you'll ever spend on a boat. Tell us about your boat.
