 Storing the auxillary dinghy motor aboard a C250
zeil
Initially Posted - 09/05/2012 :  20:28:14  Show Profile
Had some time and help from a SS shop to fabricate an out-of-the-way railing complete with mounting block for the dinghy's outboard motor.
Roland Orion, a local SS fabricator at work fabricating the railing as per my outline
The new railing blends in well with other stern modifications. Only two members are required complete with 3 fitting, a mounting plate and a little bit of teak to complete the outboard's mounting rail
Close-up of the rail
The 2.3hp Honda suspended leaving sufficient room to fully turn the C250 motor, tip it up or remove/service the motor.
Side view of the motor suspended next to the main engine with teak mounting block attached
The SS clamp-on fasteners allow for some adjustment if required.
The only problem is that for night sailing the stern light is somewhat blocked. A small price to pay for having the extra motor stored out-of-the-way and yet readily accessible
Henk & Johanna
SEAN
Response Posted - 09/06/2012 :  02:46:32  Show Profile
nice fit ,
I have alot on the back of our boat , the stern light was blocked on ours too .
we put a new light on a stern pole .
but maybe a battery powered led for a inflatable would work for a easy fix
