 Trailer for Sale
jrchase11
Initially Posted - 12/30/2012 :  10:09:24  Show Profile
7,000 lb GVWR dual-axle trailer built for Catalina 25 with following features:
<ul><li>Galvanized open Frame (c-channel) excluding jack stand risers which are tube steel </li><li>2" 10,000lb coupler</li><li>Dual 3,500lb "drop" axles get boat as low as possible </li><li>Electric brakes on both axles with 7 pin connector</li><li>Brake flush kit installed with hose adapter</li> <li>Trailer weight of 1,100 lbs so NET capacity of 5,900 lbs</li><li>Jack stands in lieu of bunks allow for maintenance</li><li>Heavy duty swivel jack used in tongue extension</li><li>Tongue extension allows easy launch/retrieval</li><li>Winch on top of winch stand </li></ul>
Price - <b>$4600 PRICE REDUCED - MAKE OFFER</b>. I may be able to help with transporting it. Email me through the link. If that doesn't work I will post email.
Trailer was purchased new in 2010. I got tired of raising my mast each time I wanted to go sailing and so I put my boat on a slip and don't use the trailer enough to keep it.
I drove the trailer roughly 650 miles (300 unloaded) to go get the trailer and my boat when I bought both. Then I have driven probably another 100 miles total on half a dozen trips back and forth from storage to ramp.
<hr noshade size="1"><b>Side View</b>
<b>Rear View</b>
<b>Tongue Extended</b><hr noshade size="1">
<b>Tongue Retracted</b><hr noshade size="1">
JohnC
'87 SR/WK #5658
Fleming Island, FL
Edited by - jrchase11 on 01/26/2013 13:59:15
putzmeister
Response Posted - 01/26/2013 :  18:07:28  Show Profile
Drum brakes?
redbaron904
Response Posted - 01/27/2013 :  17:19:41  Show Profile
I might be interested. Can you email me at br1548@hotmail.com? Thanks
jrchase11
Response Posted - 01/28/2013 :  04:45:19  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by putzmeister</i>
<br />Drum brakes?
Yes.
putzmeister
Response Posted - 01/29/2013 :  20:23:11  Show Profile
Most of us know that coming across a used C25 trailer - is rare. Finding a 2 year old trailer, galvanized and with dual axle brakes is a <i>real</i> find. Someone is going to get a great trailer!
Good luck!
dale@workinc.ca
Response Posted - 02/20/2013 :  10:35:28  Show Profile
I have a 25 catalina wing keel and started to look around for a trailer.
What is the trailer designed to fit... a swing keel or wing?
is there any extention to lower the mast or do you have a trick to do that with the trailer?
Dale
Response Posted - 02/21/2013 :  17:02:32  Show Profile
The trailer looks like it would handle a swing or wing keel easily. For a wing keel, I think I would add another keel support board over the two in the pictures and adjust the pad heights accordingly.
For raising and lowering the mast, make an A-frame out of rigid electrical conduit a la Davy J's You Tube video. I did, and it was very easy to do. works great, too.
Edited by - dmpilc on 02/21/2013 17:03:08
binky
Response Posted - 02/21/2013 :  19:34:22  Show Profile
Guy on Outer Banks, NC Craigslist was looking for on...past day or so. Not sure if he had a swing or fixed.
jrchase11
Response Posted - 02/24/2013 :  09:07:14  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dale@workinc.ca</i>
<br />I have a 25 catalina wing keel and started to look around for a trailer.
Dale
Setup for Wing currently. There are steel members under the 2x6 keel boards.
I used a mast-up mast stepper (Catalina direct sells)to hold the mast at the stern and then made an a-frame out of 1 1/2" conduit to assist in stepping the mast. I plan to keep these components so when I pull the boat I can self step the mast for misc. repairs. Mast stepping for me is unrelated to the trailer (IOW there is nothing on the trailer that helps in mast stepping).
John Joye
Response Posted - 03/23/2013 :  17:32:33  Show Profile
Where is the trailer located?
I am in Charleston SC.
John
Response Posted - 03/23/2013 :  23:19:01  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by John Joye</i>
<br />Where is the trailer located?
John
Fleming Island, FL on the SW side of Jacksonville, FL.
Edited by - GaryB on 03/23/2013 23:20:28
John Joye
Response Posted - 03/26/2013 :  11:28:12  Show Profile
Would you provide an email and/or phone # to contact you.
I may be contacted @ johnjoye@pobox.com
or cell 843-323-7703, home 843-849-0993
