 Rebed Pulpit
Initially Posted - 01/18/2013 :  07:15:59  Show Profile
I use the images to remind me what needs to be done, and to solicit your advice... like here..
1. locktight on the upper forestay turnbuckle nut ( or red fingernail polish )
2. re bed pulpit
3. repair/replace anchor locker latch
4. repair/replace/fill deadlight
Response Posted - 01/18/2013 :  07:33:56  Show Profile
If there are cotter rings in the turnbuckle, what is the nut for?
What's up with all the shackles?
Response Posted - 01/18/2013 :  07:57:12  Show Profile
The lower has a hole for a cotter pin. the upper ( from the forestay rigging ) does not have a hole.
Response Posted - 01/18/2013 :  07:59:31  Show Profile
<< What's up with all the shackles? >>
extensions .. My rig was destroyed in a storm twice ( previous owner ) and when they replaced the rigging this was the result. ain't that a deal.
The bigger mast next to it at that time destroyed my mast.
Edited by - redeye on 01/18/2013 08:00:07
Response Posted - 01/18/2013 :  08:11:27  Show Profile
When I finally order a new forstay I'll have a bunch of shackles for sale on the forum....
Response Posted - 01/18/2013 :  10:29:58  Show Profile
Don't use red locktite, it can only be undone with heat. You will probably want to adjust your rigging someday without applying heat to it. Blue (#242) is okay. However you should never need locktite for a lock nut, and that is what you have here.
This would be a good time to add an anchor roller, since you'll be doing so much work in the same vicinity.
Response Posted - 01/18/2013 :  17:58:15  Show Profile
I don't recommend running lines around stanchions/pulpit on these boats... Ever... Bluewater boat, OK...
sten
DPO "Zephyr" '82 C25 SR FK #3220
SV "Lysistrata" '73 C&C39 - Dunedin FL
Edited by - redviking on 01/18/2013 17:58:39
Response Posted - 01/21/2013 :  04:33:50  Show Profile
Thanks Sten... That's part of why I try to post many pictures, Someone will see something I don't ..
