 Where can I find wood trim ?
tomh
Initially Posted - 02/07/2013 :  03:16:59  Show Profile
Guys,
I want to modify and replace the teak panel between the stove and the seat but I can't find anyone who sells the curved edge molding profiles. Any suggestions?
Thanks in advance
Tom
1978 C25 "Karma" #790
Toledo Beach Marina
LaSalle, Michigan
Response Posted - 02/07/2013 :  05:02:14  Show Profile
From the WM site: <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Teak Edge Molding - 2 1/2" Radius, Outside Corner, 1 3/8"H x 13/16"W<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Is that what you need? I've seen in in at least one of their stores.
hewebb
Response Posted - 02/07/2013 :  06:30:11  Show Profile
If you have wood working equipment you can cut the teak lumber into thin strips and bend them around the radius, if it is not to small, and glue them in place then sand and finish. You may even be able to purchase teak veneer to do the same thing with. That makes a nice finished radius.
tomh
Response Posted - 02/07/2013 :  06:37:52  Show Profile
I never thought about WM. I checked their catalog and found bulkhead OD but no ID pcs.
I do have woodworking equipment but wanted to get something off-the-shelp.
Response Posted - 02/07/2013 :  08:44:48  Show Profile
Defender has several inside and outside radius trim pieces [url="http://search.defender.com/?expression=teak%20molding%20/%20trim"]here[/url].
Response Posted - 02/07/2013 :  20:33:13  Show Profile
West, Defender and Jamestown Distributors have wood. I have seen a respectable inventory at Defender and at some WM stores. Their are also lumber "yards" that specialize in marine woods but they typically want to sell in "board feet" quantities. If you are handy with a jig saw these sources may work. Also check with a local cabinet maker -- most will help a dedicated amateur obtain material and will guide them along.
Stu Jackson C34
Response Posted - 02/08/2013 :  11:20:33  Show Profile
The supplier of wood to Catalina Yachts is
H&L Marine Woodwork, Inc.
2965 East Harcourt St.
Rancho Dominguez, CA 9021
323-636-1718 310-638-8746
email H.1@sbcglobal.net
no website, get on their mailing list
Response Posted - 02/09/2013 :  18:22:16  Show Profile
http://www.buckwoodcraft.com
