 Mold and Mildew after the Winter Season
Initially Posted - 02/26/2013 :  07:33:53  Show Profile
So.. what we have here is a winter of rain. The lake came up 10 feet. It rained every three days for the last two months. And my deadlight leaks, so it looks like it's gonna be a moldy beginning to the new season. I've got to gear up to wiping down the inside of the whole boat with some kind of bleach solution and open it up to dry it out.
A few years back I was a little loose with the bleach and made a few holes in the fabric. Not very bright....
Response Posted - 02/26/2013 :  07:55:55  Show Profile  Visit shnool's Homepage
If you are stored on the hard with electric, can you plug in and dry the boat out with a small heater, better dehumidifier?
If you can get to it now, and cover JUST the deadlights with a tarp, but don't have electrical, you could try damp-rid.
As for removing the mildew... you can use a 50/50 solution in a spray bottle, it helps to keep you from pooling up nasty stuff and ruining upholstery.
I used to use a 100Watt utility bulb on an electrical cord to keep it dry below, but then my boat was 30 feet outside my front door. I also tarped over the whole boat (which is a real PITA when you get 2 feet of snow).
Response Posted - 02/26/2013 :  08:57:57  Show Profile
Wet slip without power.
50/50 is kinda harsh. Not sure my corneas or lungs would hold up to that..
I may go 10/90 Bleach/Water. Always looking for a store bought product that I might like more.
Simple Green is good for cleaning to me.. I like the smell, but I think it is pretty much just a soapy emulsion.
Edited by - redeye on 02/26/2013 08:58:35
Response Posted - 02/26/2013 :  09:01:38  Show Profile  Visit shnool's Homepage
Sorry mildew is my enemy I attack it with fervor... yep, it's miserable, but then I don't use a lot either. If its wet enough to create the mold then spraying more water onto it isn't really necessary.
I am also big on chlorox cleanup. I swear that stuff cleans everything. Again, it'll eat right through clothes.
Response Posted - 02/26/2013 :  09:06:34  Show Profile
I put one of these in my boat every fall when I go on the hard (click the pic for link):
<center>[url="http://www.bedbathandbeyond.com/product.asp?SKU=17732404"][/url]</center>
I also put a temp/humidity gauge with memory on the boat to monitor things. It never got above 60% RH all winter.
It's worked so well that this year I just left the cushions on the boat. No need to pull them out.
You might want to keep this in mind for next year.
Edited by - TakeFive on 02/26/2013 09:07:01
Response Posted - 02/26/2013 :  09:49:49  Show Profile
sooo... The preacher said... Oh Hell.. you don't want to go there.. It's hot... I mean it's so Hot.. Hot I tell ya..
and humid.
Welcome South Brother...
Response Posted - 02/26/2013 :  09:57:17  Show Profile
I just use Clorox Cleanup, a bucket of water and a sponge. Spray on the Clorox, wipe down with sponge...rinse sponge in bucket. Really good cleaning, smells fresh, advantages of bleach....without overpowering your lungs.
Response Posted - 02/26/2013 :  10:23:07  Show Profile  Visit britinusa's Homepage
We wipe down the insides of JD with Clorox Cleanup wipes.
The Admiral (CCRN) does not allow aerosolizing bleach on board the boat!
We buy the triple packs of the cleanups and don't get stinghy with them.
Response Posted - 02/26/2013 :  11:42:32  Show Profile
&lt;&lt; Clorox Cleanup wipes &gt;&gt;
Sweet.. I gotta try that.....sounds like a good delivery system for bleach.
Every time I use that SunIn on my hair it feels like an attempt at a homemade cure for TB... ( Cough )
Response Posted - 02/26/2013 :  11:51:37  Show Profile
http://www.llsc.com/
Is that a gray day or what.... 95% humidity
Edited by - redeye on 02/26/2013 11:52:32
Response Posted - 02/26/2013 :  12:47:33  Show Profile
I've used Bab-O Gel with a big sponge (contains bleach) on the cabin interior surfaces to get rid of mildew. It doesn't run or drip because it has thickeners. I find it about as convenient as possible for that annoying job.
Response Posted - 02/26/2013 :  15:21:18  Show Profile
Dilute is good. It's kind of a bizarre suggestion, but I take the cushions out before the bleach comes out.
TCurran
Response Posted - 02/27/2013 :  04:15:27  Show Profile
I use marine spray nine vice a bleach solution below decks. Also started using kanberry tea tree oil, so far it seems to be working. The real test will be this summer.
Response Posted - 02/27/2013 :  06:20:18  Show Profile
This is 1/3 of the cleaning products on the never ending shelves.
So... I go to the Flagship Home Depo which is next to where I work and get some Clorox Wipes and begin looking for another cleaning product and the first product I pick up says "Bleach Alternative" but the back reads "do not use with bleach" and then I just go into brain lock.
So Many Choices and I just lose it. Never did see the Kanberry tea tree oil... I'm beginning to hate marketing.
Edited by - redeye on 02/27/2013 06:21:17
trptelf
Response Posted - 02/27/2013 :  19:11:34  Show Profile
Clorox Disinfecting Wipes do not contain bleach. Thank goodness. I found this out after accidentally spilling what was left in the container on one of my navy cushions. No problem as they do not contain bleach. I use them all over the interior.
Response Posted - 02/27/2013 :  20:38:34  Show Profile
Ray,you guys are fortunate to get that 10 ft rise in lake level. It will help come summer. If you have a home carpet cleaner with a wand attachment, take the cushions home, put a 10/90 bleach/water solution in the clean water tank and run the wand lightly over your cushions and let them dry. While the cushions are out, wipe down the interior of the boat and let it air out/dry. Then put in 2 buckets of Damp-Rid.
TCurran
Response Posted - 02/28/2013 :  04:14:11  Show Profile
Ray, here a link to Kanberra
http://www.kanberragel.com/kanberragel.php
Response Posted - 03/18/2013 :  03:46:02  Show Profile
Thank You Paul ( and others ) and tell the ccrn thanks for me.. the clorox wipes rock. Much easier than adding/spraying a solution and then trying to clean up the mess...
Response Posted - 03/18/2013 :  04:32:11  Show Profile  Visit britinusa's Homepage
We get the Triple pack every time, if they sold them in 6packs... happiness!
Response Posted - 03/18/2013 :  07:57:35  Show Profile
Ordinary white vinegar works very well on mold & mildew - no residual smell either (and it's dirt cheap!)
Response Posted - 03/18/2013 :  12:28:01  Show Profile
Derek: Have you tried it on the black spot mildew that shows up on decks? That's a big problem here in Seattle, and I'd prefer to use a cleaner that doesn't contain bleach (not great for gelcoat) or buy/borrow/rent a power washer.
Response Posted - 03/18/2013 :  13:06:53  Show Profile  Visit Prospector's Homepage
We use a powerwasher on the outside and a pump/spray (like for spot treating lawns) inside. So far so good.
Only caveats are that the powerwasher will eat your teak if you don't protect it.
This spring I am doing hte scrub-brush thing on the exterior and hope to get the decks waxed before launch. Dunno how else to treat chalky gel coat up there. Only other alternative is the non-skid cleaner that didn't do much last time.
Response Posted - 03/18/2013 :  15:03:26  Show Profile
Alex - are you sure that those black spots are not spider poop? That's the cause of them on my boat. The only thing I've found that works is Chlorox Clean-Up and a good scrub.
For a chalky oxidized hull, the best product, bar none, is PolyPrep followed by 5 coats of PolyGlow - great shine and needs a new coat every year or two. No power buffing, just wipe on and let dry.
Response Posted - 03/18/2013 :  18:02:00  Show Profile
Polyglo is back on my to do list again. But make sure the stains and spots (and oxidation) are completely gone or you'll memorialize them under the polyglo. I've had good luck with deck cleaner with PTFE for the cabintop and decks. Less dangerous than waxing and buffing.
Response Posted - 03/18/2013 :  18:31:39  Show Profile
Yeah, I'm sure it isn't spider poop. Spider season around here is August. The black dot mildew is really common in Seattle, you'll see it on most boats if you look.
The fiberglass on my Pearson isn't chalky, it is in pretty good shape. The Catalina is a bit chalky and has way more black mildew spots.
I'll try the vinegar and report back.
