 ethanol and clogged jets, and a small motor
steve25
Initially Posted - 04/28/2013 :  14:47:41  Show Profile
So after doing all of the bottom work and getting her in the water. I started the motor for the first time to find out the only way the Mercury 9.9 Bigfoot would run is 1/2 throttle and full choke. Less than optimal. After talking to many sources, I find that I need a carb rebuild. Due to what I am told is the ethanol gas. Not wanting to delay the season at all, while this is being done I'm wondering if my Dinghy kicker, a 2.5 Yamaha short shaft would move the boat enough to make a few trips. Has anyone tried this? Is this real stupid, or just sorta stupid?
1986 C-25 SR/FK #5427
AkaBud
Response Posted - 04/28/2013 :  18:14:07  Show Profile
If you haven't taken the carb off already I'd try this first.
It will clean the deposits out of your carb.
http://www.seafoamsales.com/sea-foam-spray/
Than always use Seafoam in your fuel to prevent further problems.
Response Posted - 04/28/2013 :  18:54:41  Show Profile
Ethanol may be a convenient excuse... Varnish, caused by gasoline evaporating in the jets and sometimes gumming up the carb float, is also a possible (maybe probable) explanation. That problem predates E-10 gasoline by many decades, and the newer 4-strokes with their finer jetting exacerbate it. Carb cleaners are worth a try, followed by cleaning the carb.
Hey--it's a boat. There's always somethin'. (I'm dealing with my own "somethin's" right now.)
Edited by - Stinkpotter on 04/28/2013 18:55:14
Response Posted - 04/28/2013 :  19:55:13  Show Profile
What kind of water do you sail on? If your motoring is protected (no or minor waves) then your dinghy motor should be fine, just slow.
Response Posted - 04/28/2013 :  22:26:47  Show Profile
I powered a 21 footer with a 2 HP for a few weeks. It displaced a little under 2000 pounds and had a much finer entry that a C-25 and moved along at 3 knots.
Response Posted - 04/29/2013 :  04:50:25  Show Profile
If your Mercury is a newer model, made by Tohatsu, you might only need to clean the low speed jet.
cshaw
Response Posted - 04/29/2013 :  06:59:01  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by steve25</i>
<br />After talking to many sources, I find that I need a carb rebuild. Due to what I am told is the ethanol gas. Not wanting to delay the season at all, while this is being done I'm wondering if my Dinghy kicker, a 2.5 Yamaha short shaft would move the boat enough to make a few trips. Has anyone tried this? Is this real stupid, or just sorta stupid?
Hi Steve! Not Stupid at all! My 9.9 Johnson was down for several months while I rebuilt it and I used a little (and old) 4hp Johnson Deluxe on Confetti. Worked fine but going into a stiff breeze or chop was at best slow, and sometimes almost not possible, so pick your weather. Also, there is not enough thrust to count on using the motor for slowing down quickly coming into your slip (if you normally use the motor for braking)
I agree with the posts that ethanol is not the only thing that can gum up a carb! However, it is sure bad on things! I picked up a used fishing boat and the ethanol had disollved the lining in the fuel lines!! (the dealer had a section to show what happens and it was just like mine). The debris and residue from the fuel line lining had severly plugged up that engine's carbs... I was amazed that it had made it thru the small filter in the engine (you may have to replace that also if your fuel lines are deteriorating). Its a slow process however, especially if you use any ethanol treatments in your gas, so its not always as bad as it sounds.....
So consider getting the ethanol tolerant line/squeeze bulb when its replacement time, and perhaps even the lines inside the motor. And for sure use an ethanol treatment in your fuel..... You can sometimes find ethanol free gas, but it costs about $0.50/gal more where I am.
If your motor is 2 cycle, I highly recommend always running the motor dry of fuel after you are back at the dock if it is going to sit for a while. The gas slowly evaporates and the oil in the gas is left to form deposits in the fuel bowl that get into the lower jet. Just let it idle till it finally quits.
Like Stinkpotter correctly observed "Hey, its a boat, there's always somethin'!!"
Cheers!
Chuck
CarbonSink62
Response Posted - 04/29/2013 :  08:35:56  Show Profile
When I launched last year, my Evinrude 9.9 wasn't running, so my brother and I used the 5hp 2stroke short shaft from my son's boat to get from the marina to the mooring (5-6nm sheltered river, but big ships/wake).
It did the job, but:
We had to fill the water tank to lower the stbd side.
We overfilled the tank (into the bilge) and left it there for more draft.
If one of us went forward, the other had to stay all the way aft or it would ventilate.
We were pinned against the pier by the current at first because there was so little thrust.
Reverse was all but useless for stopping forward motion.
Even being careful, we still ventilated a few times when big boats passed us.
I'm on a busy river with current; I would do it again to move the boat from A to B ('cause B is so nice!) but not to go sailing. On a lake, on a day with light wind, a 4-5hp would be good enough. If the lake were big enough to create chop and the wind rose from the predicted 6-10 to maybe 12-16 and that chop started up; you might find yourself in a pickle.
Excessive ventilation can destroy the water pump, that will not improve your situation.
Ken
Response Posted - 04/30/2013 :  12:29:00  Show Profile
I see that you sail out of the Middle River in Baltimore/Essex, Maryland.
I borrowed a friend's Mercury 2.5 hp outboard while my regular engine was in the shop. It would easily push the boat out of the marina into the Magothy River (about 10 miles south of your marina) but I didn't count on it getting me out of trouble in the Craighill Channel shipping lane or pushing the boat against a strong breeze.
I clamped an 18-inch piece of 2x4 horizontally to the bottom of the outboard bracket using big C-clamps and attached the little outboard to that piece of wood so that it rode at a proper depth.
A small engine like that can get a C-25 up to about 4 knots in calm conditions.
Happy sailing!
ftworthsailor
Response Posted - 04/30/2013 :  12:32:28  Show Profile  Visit ftworthsailor's Homepage
and -4knots in strong winds or current conditions.......... I know this for a FACT ! ! !
Response Posted - 04/30/2013 :  12:40:33  Show Profile
Well, you don't have strong currents on the Chesapeake Bay. If you are stuck out on the Bay and the strongest winds from the front edge of a thunderstorm are pushing you to a lee shore and towards disaster, then you just calmly drop the anchor and let it pass over for half an hour while you play cards down below.
Otherwise, in mild conditions you're fine with a small motor, in moderate winds you're having fun sailing with a small motor, and you know how to reef the main and pull in the roller furling or bend on a storm jib in high winds. It's sailing, and that's what we do!
See you out on the Bay!
hinmo
Response Posted - 05/01/2013 :  09:08:39  Show Profile
Wow - I can relate to every part of this story. I have an almost new (2009) extra long shaft 4strk 6hp Tohatsu that has been the MOST unreliable engine I have owned. Works sometimes and dies other times. I am down to potentially buying a new carb and fuel pump as a last resort (been thru 2 mechanics, new hoses, carb rebuild, new bulb, new tank...etc)
Meanwhile, bought a $75 1994 4 hp Mariner 2-strk long shaft (not extra long) off CL. In a bakeoff in the driveway, the Mariner is the much better running machine and I will launch the boat with it this coming season. First big challenge will be backing her out a tight passageway between two wharfs with boats tied-up on each side...potentially into a prevailing 10-15 kt wind. Wish me luck!
Edited by - hinmo on 05/02/2013 03:04:16
Response Posted - 05/02/2013 :  07:37:50  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by hinmo</i>
<br />Meanwhile, bought a $75 1994 4 hp Mariner 2-strk long shaft (not extra long) off CL...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...for a C-25 on Buzzard's Bay?? <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Wish me luck!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Done!
Edited by - Stinkpotter on 05/02/2013 07:38:29
hinmo
Response Posted - 05/02/2013 :  09:34:44  Show Profile
low power, beats no power!!!
Response Posted - 05/02/2013 :  11:03:34  Show Profile
My Honda 9.9hp 4-stroke was unreliable until I learned to always flush the salt water out of the cooling system (to keep the impeller from disintegrating each season) and run the engine dry at the same time (to avoid wet E10 gasoline and starting problems). Since I do both of those things, the outboard starts on the first pull each time!
I run the gas out of my lawn mower, too. And the Stihl 2-stroke chain saw I bought last Fall instructs the owner to run the engine until it stalls after all the gas-oil mixture is gone.
I am really happy with the Honda 9.9 these days!
Note added: Also got a new gas tank and new bulb and fuel line in 2011.
Edited by - JohnP on 05/02/2013 11:04:52
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 05/02/2013 :  16:11:00  Show Profile
When I read the subject of this thread, I thought ethanol was going to be the solution not the problem.
cat25
Response Posted - 05/02/2013 :  18:11:19  Show Profile
I flush my honda 9.9 every time its used. The end of the boating season I flush the motor in a plastic garbage pai;. Its filled with water and extra virgin olive oil while its running. The motor is a 2002 model with the same impeller. Its used in salt water.
