 Pop Top Trim?
Headhunter
Initially Posted - 05/12/2013 :  10:07:43  Show Profile
Have a 1986 Cat 25 TM, hull # 5231.
Need to replace the pop top trim...Catalina Direct sells 11 foot pieces for almost $40. 11 Feet is not long enough to do the whole thing, so need to buy two and waste most of the one.
Has anyone found an alternative? Did a search of this board but did not find anything.
Tomas Kruska
Czech Republic
Response Posted - 05/12/2013 :  12:47:04  Show Profile  Visit Tomas Kruska's Homepage
I had previous model without groove for the gasket, but I used self-adhesive rubber D profile I found localy.
Worked great for foward window and poptop.
Headhunter
Response Posted - 05/12/2013 :  14:22:21  Show Profile
Thanks, but I mean the vinyl trim around the cabin pop-top. Actually not the top, but the area around the opening.
This stuff: http://www.catalinadirect.com/index.cfm?fuseaction=product.display& product_ID=186& ParentCat=31
Edited by - Headhunter on 05/12/2013 14:23:32
Response Posted - 05/12/2013 :  14:58:33  Show Profile
Use teak batten instead.
Headhunter
Response Posted - 05/12/2013 :  15:38:20  Show Profile
Now that would look good, but it'd be a pretty detailed job to get it to curve around and it needs a lip.
Response Posted - 05/12/2013 :  15:42:05  Show Profile
Possibly this will work, 1" wide RV trim. http://www.acehardware.com/product/index.jsp?productId=18889306No guarantee's.
Edited by - islander on 05/12/2013 15:43:59
Response Posted - 05/12/2013 :  15:46:04  Show Profile
That trim serves no purpose, it is a beauty ring.
Response Posted - 05/12/2013 :  15:58:09  Show Profile
I think it hides the joint between the cabin top and the liner. Try the swap meet for someone parting out a boat.
Headhunter
Response Posted - 05/12/2013 :  16:04:36  Show Profile
Scott - that is what I replaced the original with, but the adhesive just doesn't hold up...Am considering another adhesive, but thought I'd ask here to see if anyone has found another alternative first.
Frank - yeah, but it sure looks bad without something.
