 question on 3rd set of halyards
cayugaboater
Initially Posted - 06/30/2013 :  23:42:40  Show Profile
89 catalina 25, my main sail halyards exit from inside the mast on the starboard, jib on port and then there is a third set of lines going to the masthead to a pulley that are external and on the stern side of mast...what are those for?
( I have a roller furler jib)
89 wingkeel;std rig.
Sail #5811
hewebb
Response Posted - 07/01/2013 :  04:18:09  Show Profile
One may be for a topping lift.
CarbonSink62
Response Posted - 07/02/2013 :  04:40:11  Show Profile
I agree, sounds like a topping lift. In light air, a topping lift prevents the weight of the boom from affecting sail shape. At anchor, it allows you to swing a small person over the side of the boat and torment them by slowly dipping them toward the water (I've read).
Ken
Edited by - CarbonSink62 on 07/02/2013 04:53:04
Lee Panza
Response Posted - 07/02/2013 :  20:37:06  Show Profile  Visit Lee Panza's Homepage
A topping lift also supports the boom for lowering or reefing the sail without having to clip it to the backstay (I never liked to clip the boom to that pigtail when the wind was getting so strong that I wanted to lower or reduce the main). If your mystery halyard has some kind of clip on one end, that can clip into one of the holes in the fin on top of the boom-end casting, and if it's long enough for the other end to reach a cleat on or near the mast (you didn't indicate that your halyards are run back to the cockpit), then you can use it as a topping lift. I know that a lot of people don't have one, and probably don't feel the need for one with a mainsail as small as we use, but it's very handy once you get used to having it.
KenDavis
Response Posted - 07/03/2013 :  09:58:19  Show Profile
spinnaker halyard ?
oops- "pulley on the stern side of mast" not a spin halyard.
Edited by - KenDavis on 07/03/2013 10:01:39
windseaker
Response Posted - 07/03/2013 :  11:48:22  Show Profile
It is definitely the topping lift I have the same thing on my boat and it's even marked TOPPING LIFT
hottubjim
Response Posted - 07/07/2013 :  20:39:29  Show Profile
My boat also has the topping lift. The previous owner used it in a Dutchman main sail lower system (like a lazy jack but different).
