 Jib furler line
moserd
Initially Posted - 09/30/2013 :  09:53:02  Show Profile
Anyone replaced their jib furling 'reef' line? Mine packed it in the other day and I was wondering if anyone has replaced one? Book indicates 3/16 inch but mine came with 1/4 inch. 3/16 seems too small for me. Any idea of the capacity (load) requirement?
Don
#817
2005 WK
Don Moser
szymek
Response Posted - 09/30/2013 :  10:01:54  Show Profile
As long as your drum has capacity to take it with your sail rolled out, I don't see any issue with that and I'd go with 1/4. Handling thin line with bare hands is a different issue, but 3/16th should be enough (that's what I have on my furler).
Response Posted - 09/30/2013 :  10:27:33  Show Profile  Visit OLarryR's Homepage
Agree to go with the largest that can fit on the drum. I have found that the the smallest diameter lines are harder on the hands (even if wearing gloves) and the line rarely but can tend to get tangled occasionally on the drum when using the smallest lines. What you can do if you are hesitiant to go with 1/4" but want something greater than 3/16" is to go with those lines specified in mm and slightly greater than 3/16". That may work for you. I forget what mm that is but you can easily make the conversion typing the conversion question into Yahoo or Google.
Response Posted - 09/30/2013 :  14:08:54  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by moserd</i>
<br />...Any idea of the capacity (load) requirement?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">The load requirement should be negligible relative to the capacity of almost any size double-braid you can buy. Go with what fits and feels OK. If 1/4" worked for your sail (the larger the sail, the longer the line must be), I'd stick with that.
Tahoe Cruiser
Response Posted - 10/01/2013 :  13:01:36  Show Profile
I believe my line is bigger than 1/4 inch. I had to message the end to get it through the small attachment hole and the drum. All my line fits on the drum with a 135 fully out. 1/4 inch will work IMO.
