 Ideas please, how to lock down a kick-up rudder
Initially Posted - 10/24/2013 :  10:07:08  Show Profile
I do not care for my kick-up rudder. If a kick-up is not completely down by even a few degrees the helm gets very heavy. I am not impressed with the mechanism on the rudder, it uses an eye strap on the rudder and a line lead to a cleat on the tiller.The line up through the grommet in the tiller is the down haul. I cannot get the rudder vertical with the line so I have to use a boat hook and push down on the up-=haul eye strap to get the last few degrees and feel the system is susceptible to stretch and slip. I feel like a pin system would be difficult to get aligned adequately during the modification process to guarantee the perfect angle and would require a sleeve to be epoxied into the rudder to be done right.
Edited by - pastmember on 10/24/2013 10:26:19
Response Posted - 10/24/2013 :  10:11:37  Show Profile
Mine has a shear pin that holds it down unless I run the rudder into a rock. I don't have a photo but, it's located aft of the pivot pin through the metal plates on both sides of the rudder.
$6.95 for 2 at Catalina Direct.
Edited by - John Russell on 10/24/2013 10:15:10
Response Posted - 10/24/2013 :  10:31:06  Show Profile
Rudder Craft uses a gas strut mounted to pins on the rudder head and the blade, positioned so that the strut compresses as the blade passes from full up to full down, and extends in those two positions. You could put your engineering cap on and figure out the two pin locations and strut size... But if the rudder very rarely touches anything, the shear pin is probably simplest.
Edited by - Stinkpotter on 10/24/2013 10:39:31
Response Posted - 10/24/2013 :  11:00:13  Show Profile
On our C-22 the kick-up rudder would slip up slightly in heavy weather. In order to hold it fully down, we drilled a 1/4" hole through the metal plates and rudder. At first we used a long quick releaase pull pin, but that bent one day when we went aground. Now we use a short piece of 1/4" wood dowel, with several spares on board for back-up. The wood dowel will hold the rudder blade in place, and if we ground hard, it will shear off and can be replaced easily. On your rudder, I would drill the hole forward of and level with the pivot pin.
panhead1948
Response Posted - 10/24/2013 :  13:21:45  Show Profile
Looks like the rudder on a Starwind. I had a Starwind 19 and I just put the rudder down and tightened the pivot bolt down fairly tight.
Response Posted - 10/24/2013 :  15:46:08  Show Profile
Yes I sail a Starwind 223. I am a little concerned about "crushing" the fiberglass on the rudder if I crank the bolt but that might be the place to start.
Response Posted - 10/24/2013 :  16:43:35  Show Profile
on my 16 ft daysailer, I have a pair of springs that are attached on one end to the metal section and the other end to the rudder. The springs contract when the rudder is full up, or full down. When 1/2 way, the spring if fully extended. If you look at a Laser or Sunfish, you'll see a similar arrangement. Take a look at this brief [url="http://www.youtube.com/watch?v=-iB5bsoH6zY"] video [/url].
