 My Modifications 2013
philagnes2003
Initially Posted - 10/28/2013 :  03:09:36  Show Profile
So we made some nice improvements in the spring of 2013, and I am happy to say they all greatly improved our sailing/boating experience.
I remove the single port clutch and replaced it with a triple XAS, on that clutch we have the outhaul, with a new line on it, Jib furling, and the single line reefing. The reefing has blocks on the sail, and works really well; the tack goes down first and all. I finally have the leverage to trim the sail with the outhaul. We had the rear berth cushion recovered, and we added a ½ of a high density foam on top, and we added an interlocking rubber matt under the cushion to block moisture. I used Marine Tex to finally fix (permanently) the rear berth leak from the starboard cubby. The battery area was bone dry when I removed the battery! We changed the water pump, and had the motor tuned so now it idles real low.
Great season, no issues, what to do next year?
Mac's Bounty
2003 C250 WK #679
Orient Harbor, NY
If you think you can, or think you can't, pretty soon you find out your are right! H.F.
Response Posted - 10/28/2013 :  11:10:48  Show Profile
"'salways somethin'" --Rosanne Rosannadanna
