 Masthead sheaves.
Tahoe Cruiser
Initially Posted - 11/06/2013 :  21:38:06  Show Profile
So I noticed I have four sheaves in my masthead. I am only using the aft one for main halyard. I have a rigid furler up front so those are free as well. I think the PO has a beat up spare forward halyard for spinnaker but no block on top. Do you all use the internal forward halyard for the assymetrical spinnaker or do you run both ends outside of mast to a block? What else can u do with the spare aft sheave? Is this meant for topping lift and if so how is the line run? I want to replace all for sheaves before next season as they are stock and chipping.
1998 250 WK/TR #355 "Trail Break"
Lake Tahoe California
Edited by - Tahoe Cruiser on 11/06/2013 21:39:37
zebra50
Response Posted - 11/09/2013 :  08:36:43  Show Profile
On my masthead forward, I have one spot taken up by my furler, the other is "open", and the jib halyard is used for my light air sail. It is tied off when not in use. See pg 17 of the owners manual which you can get here on this site.
Response Posted - 11/09/2013 :  08:44:10  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Tahoe Cruiser</i>
<br />So I noticed I have four sheaves in my masthead. I am only using the aft one for main halyard. I have a rigid furler up front so those are free as well. I think the PO has a beat up spare forward halyard for spinnaker but no block on top. Do you all use the internal forward halyard for the assymetrical spinnaker or do you run both ends outside of mast to a block? What else can u do with the spare aft sheave? Is this meant for topping lift and if so how is the line run? I want to replace all for sheaves before next season as they are stock and chipping.
It sounds like you have a different masthead than most of us. There are relatively few tall rig C250's and the early ones had a masthead with four sheaves. Most have only two. So be careful that the advice you get is relevant to your own masthead.
Here's a pic of the bottom of the four-sheave masthead:
<center>[url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=1913&ParentCat=631"][/url]</center>
Tahoe Cruiser
Response Posted - 11/09/2013 :  19:45:35  Show Profile
I was confused when I saw the forward sheaves free. I would think an internal forward halyard for my assymetrical spinnaker would foul if I tried to run it through a block at the stock spinnaker crane. I would prefer an internal run then tie off the unused halyard to the forward pulpuirt so I don't have the annoying line slap on the mast. That picture above is my masthead.
Response Posted - 11/09/2013 :  22:58:33  Show Profile
<br />...I would prefer an internal run then tie off the unused halyard to the forward pulpuirt so I don't have the annoying line slap on the mast. That picture above is my masthead.
For my unused halyard, I give it two wraps around a lower shroud then attach to the bails at the base of the stanchion. With mild tension, there is no slapping on the mast. I so the same with my mainsail halyard when at the dock.
