 Convert to pressurized cold water system in my 250
philagnes2003
Initially Posted - 12/31/2013 :  05:12:15  Show Profile
I am thinking about a winter project, I would like to possibly convert to a pressurized cold water system in my 250. I think this can be done fairly cheap.
So I add this type of motor near the tank: $80
http://www.shurflo.com/marine-products/marine-pumps/fresh-water-pumps/aqua-king-fresh-water-pumps/default.html
I need to change my fixtures, I have the whale:
http://www.whalepumps.com/marine/product.aspx?Category_ID=10016& Product_ID=10025& FriendlyID=Whale-V-Pump-hand-operated
What faucets can be easily retrofitted?
Is this a worth while project, has anybody made the conversion?
Mac's Bounty
2003 C250 WK #679
Orient Harbor, NY
If you think you can, or think you can't, pretty soon you find out your are right! H.F.
Response Posted - 12/31/2013 :  06:09:48  Show Profile
My boat came with this in the galley:
http://www.shurflo.com/marine-products/faucets/electric-faucets/electric-faucets/default.html
It pressurizes just the one location, not whole boat. And it does it on demand, instead of maintaining pressure all the time.
My head has the original manual pump.
I think having just the one faucet pressurized is good enough.
Response Posted - 12/31/2013 :  07:59:35  Show Profile
I don't see why you can't split off the output line--mine goes to the galley sink and to the head. Using either one relieves the pressure, which turns on the pump. I don't remember my pump model, but it's relatively small with a pressure switch so it runs "on demand." If the pump is rated for fewer outlets than you have, that should just mean you might not be able to use all of yours at the same time.
Edited by - Stinkpotter on 12/31/2013 08:10:27
Response Posted - 12/31/2013 :  08:39:34  Show Profile
An alternative that you might consider is a Whale Gusher Mk3 Galley Pump (currently about $100. at Defender) With a pressurized system, the tendency is to turn on the faucet and let it run, however briefly. You can pump 10-12 gallons of water much more quickly than you might imagine. Moreover, the system is dependent on a functioning electrical system and charged battery. The mechanical galley pump is foot operated, leaving both hands free to wash dishes or to wash your hands. It provides a strong stream, but only while you are intentionally pumping it. It can't be accidentally turned on. It helps to conserve your limited water supply.
philagnes2003
Response Posted - 01/01/2014 :  12:46:12  Show Profile
Thanks, I like the electric faucet idea, pretty cheap on Amazon:
I think I will go with this in the galley, and keep the manual in the head.
Thanks!
Response Posted - 01/01/2014 :  13:38:12  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by philagnes2003</i>
<br />Thanks, I like the electric faucet idea, pretty cheap on Amazon:
Thanks!
f.y.i, my pump is installed on the bottom side of the floor of the galley cabinet.
zeil
Response Posted - 01/02/2014 :  13:55:24  Show Profile
You may wish to consider a pump similar to the one we have in our '95 C250 WB.
If the boat is exposed to below freezing temps you should drain the tank, pump and lines.
Edited by - zeil on 01/09/2014 08:54:12
zeil
Response Posted - 01/02/2014 :  14:02:22  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by zeil</i>
<br />
The pump, faucet and parts, if required, are readily available at RV and marine stores and used extensively
Edited by - zeil on 01/02/2014 14:03:06
Ian Brisbane
Australia
Response Posted - 01/03/2014 :  01:46:58  Show Profile
Hi. We put a sure flow pump in it runs all the taps on one line( one at a time) and we also put in a transom shower on the port side insert. We use it to wash off after a swim and wash the dinghy motor etc works well for spilt beer as well :)
philagnes2003
Response Posted - 01/09/2014 :  03:39:20  Show Profile
Thanks Ian, do you have a picture of the Stern shower that sounds cool. Also what did you change your sink faucets to? Do you have a link to the pump, and I guess you mounted the pump to the exit line of the tank right?
Response Posted - 01/09/2014 :  04:59:26  Show Profile
We just purchased an R.O. system for home, and the faucet would be perfect for your solution. google is your friend on the home RO systems, uses 1/4" OD tubing and can be had in multiple finishes.
Response Posted - 01/09/2014 :  10:25:27  Show Profile
The alternative I chose was to leave the existing fixtures but add a pump that supplies a 25' hose that is coiled and stored in the galley cabinet. It is very convenient to fill sink or rinse dishes or extend out the hatch to rinse off a swimmer or for rinsing the boat after loading on the trailer.
kc5dlo
Response Posted - 01/09/2014 :  11:36:47  Show Profile
I had my boat for 6 months before i discovered an electric pump was installed. It is installed inline on the hull under the galley sink. There is a small momentary switch at the base of the cabinet that operates the pump. The faucet is the stock pump with the lever. I found the pump when running new speaker wires and accidently hit the switch I knew nothing about. Kind scared me lol.
Had a similar set on my last boat and liked it. You could still use the hand pump without turning on the electric pump too.
Ian Brisbane
Australia
Response Posted - 01/12/2014 :  17:09:54  Show Profile
Happy New Year. Will take some pics and post
