 Sail Slugs
Bryan Beamer
Initially Posted - 02/16/2003 :  11:09:57  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>it would be a good idea to raise the sails and make sure the slugs aren't getting caught in the track on the mast <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
I know we talked about this before. I seem to have misplaced my notes on this subject.
What is the stuff called to make the slugs go up & down in the track easier and where do you purchase it
Bryan Beamer
<img src="http://im1.shutterfly.com/procserv/47b3dc23b3127cce9462f2858f2b0000001010" border=0>
Daylight Again
Edited by - Bryan Beamer on 02/16/2003 11:12:23
glstout
Response Posted - 02/16/2003 :  11:21:41  Show Profile
Brian,
We use silicon spray and you can get it at Walmart or similar stores. Use caution to direct it inside the track and not on sail. Someone may have another remedy.
Good luck
Gordon
gls
Buzz Maring
Response Posted - 02/16/2003 :  11:36:44  Show Profile
Hi Bryan,
I haven't tried it, but I've heard that liquid dish soap also works well ... ?
Response Posted - 02/16/2003 :  11:58:44  Show Profile
That was Bill Holcomb. I would add that each time it rains, your track gets cleaned out...
I like Super Lube, which doesn't seem to evaporate, wash away or collect dirt. A petroleum lubricant I once used all ended up on the deck after the first hot, sunny day. Dish soap would've been much easier to clean up!
John G-
Response Posted - 02/16/2003 :  12:23:52  Show Profile  Visit John G-'s Homepage
<font size=2><font face='Comic Sans MS'>I’ve been using “Fastrack”. I got it from West Marine. It doesn’t leave a residue and comes with an applicator for the mast track. It cleans and lubes the track then you put it on all the sail sluges. It works great all season.
</font id=size2> </font id='Comic Sans MS'>
[url="http://www.peregrinefund.org/"]<img src="http://www.peregrinefund.org/images/intro_mid_image.GIF" border=0>[/url]
<font face='Comic Sans MS'><font size=2> John G- "PEREGRINE" C25-#4762 FK </font id=size2></font id='Comic Sans MS'>
lcharlot
Antigua and Barbuda
Response Posted - 02/16/2003 :  12:46:15  Show Profile
One other thing about sail slugs - they come in two kinds, the better ones have a stainless steel reinforcement, the cheap ones are just plain plastic and only last two or three years before breaking. Carry a few spares, they only cost $1.50 or so, and you are practically guaranteed to have to replace one every so often. Get the reinforced ones, they only cost a few cents more than the all-plastic and last a lot longer. In fact, I don't recall ever breaking a reinforced slug, all the failures I have had were on the original Catalina factory slugs which were the all-plastic kind.
Larry Charlot
Catalina 25 #1205 "Quiet Time"
Sacramento, CA
Ben - FL
Response Posted - 02/16/2003 :  13:54:43  Show Profile  Visit Ben - FL's Homepage
I've got a sail slug that needs replacing. Trouble is that they are sewn on to the mains'l. On the 250 there are two grommets for each slug and a tether sewn top to bottom with slug in between.
Safe voyages,
Ben, FL s/v Chick-a-pea C250wk
<img src="http://www.members.aol.com:/benraye/pictures/fullsail.jpg" border=0>
SEA DOG
Response Posted - 02/16/2003 :  17:04:21  Show Profile  Visit SEA DOG's Homepage
Hi, try Team McLube SailKote, it works.
Seadog FK/TR 4232
Bryan Beamer
Response Posted - 02/16/2003 :  18:58:45  Show Profile
Thanks guys
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> ?Fastrack?. I got it from West Marine.
Fasttrack was the stuff I made a note of last time this threads came up.
I have tried dish soap & Crisco (not the oil but the white stuff in the tub) on snaps for cock pit cushions & the poptop cover before, it works well there. I don't see why it would not work on the sail slugs.
Thanks again<img src=icon_smile.gif border=0 align=middle>
Bryan Beamer
Daylight Again
C250wk #495
Response Posted - 02/16/2003 :  20:32:45  Show Profile
Crisco will work for a day or two, and then you'll have to scrub it off the cabin top. BTW, I suggest candle wax for snaps--easier to store on board, easier to apply, and doesn't melt away quite as fast.
Edited by - Dave Bristle on 02/16/2003 20:35:58
Dennis Pierce
Response Posted - 02/17/2003 :  08:28:21  Show Profile
I replaced the 3/8" slugs with 1/2" slugs with the stainless steel loops. Sails go up and down smooth with a little help from Fast Track. Seems the smaller slugs wouuld jam up when using a down haul. This could be a factor of age and wear.
Dennis Pierce
Gypsy Witch #1719
dgabel
Response Posted - 02/17/2003 :  16:33:45  Show Profile
I used the dish soap last season. Applied it to the slugs before I raised sail the first time. Found I had to reuse it several times through the season.
It worked well until the weather got cold, and then I found it hardened, or got gummy, or something like that, so when I sailed to the ramp to put her on the hard for the winter it was really tough dousing sail. I'm going to try using Fastrack next time.
Dave Gabel
Walkure
Sail 1484
