 repair rails
fmarcelino
Initially Posted - 05/05/2014 :  09:30:43  Show Profile  Visit fmarcelino's Homepage
Hello group,
On my list of things to do to get the boat ready for the water, is that I wanted to fix the rails in a couple of places where there is some cracking and it looks like some water is getting through.
I want to remove the screws, cleanup underneath, and then seal around the whole thing. What type of "goop" should I use to seal around the base of the rail?
Thanks in advance,
Phil
Owner 1982 Catalina 25 (Bel Canto), 89 Merc 9.9hp outboard
Read about my sailing adventures on my photo diary at:
https://belcantosailingphotos.shutterfly.com/
Response Posted - 05/05/2014 :  09:42:36  Show Profile
I used butyl tape. No drips, no runs, no errors, no leaks.
I used a straw to make the hole for the screws.
WesAllen
Response Posted - 05/05/2014 :  11:26:31  Show Profile
By all means use the butyl rubber tape. I tried the 3M stuff and it leaked the next year. I purchased the butyl rubber from 'mainsail' on Sailnet.com. It is great stuff and much easier to work with. The only thing I have found to make my windows not leak. I will be sealing more things this spring (stanchions, etc.)
Wes
Response Posted - 05/05/2014 :  13:12:35  Show Profile
Polysulfide is my choice. More time up front, but it will be good for decades, 20 - 30 years. Butyl tape will eventually squish and leak, but on the plus side, it is easy to replace.
fmarcelino
Response Posted - 05/06/2014 :  07:06:45  Show Profile  Visit fmarcelino's Homepage
Awesome. Thanks for the tips everyone!!
