 rudder downhaul
mdidomenico
Initially Posted - 06/16/2014 :  06:16:05  Show Profile
I took my (new to me) 1995 250WB out this past weekend for the first time. it was a little windy for sailing, but we motored out and bobbed for a bit.
To get out into the bay I have to travel along a channel which seems to get a little shallow in parts and it kicked up my rudder. Turns out the rudder doesn't kick back down and doesn't seem to have a downhaul rope.
The cheek clamps seems to hold it down nicely, until I bump something. then i have to loosen the clamps and stick my leg through the rail to push it back down with my foot. (which is a little precarious while under way)
My question is, am I supposed to have something to pull the rudder back down? Am I missing some part in the system?
thanks
Response Posted - 06/16/2014 :  08:03:14  Show Profile
The original design did not provide a pull down line. In fact, the original design was poor in many respects. It uses what I call a rivet detent hold down design, where rivets inserted into the rudder, when their heads align with holes in the rudder head, hold that position when the rudder head halves are clamped under pressure.
The problem is the rivets quickly wear at the hole and soon the rudder is positioned somewhat aft which causes the helm to suffer great loads due to the rudder not holding a forward position against the rudder head frame.
Fortunately, one can discard the original system in trade for a better. What is required is to remove and discard the rivets and add a cheek block, cleat and bungee line to the rudder head. Use of a bungee provides for a pull down line as well as an automatic pull down following a grounding.
http://pages.suddenlink.net/arlyn/sailing/rudderheadmods.html
If the screws are difficult to remove from the rudder head, the rivet heads can be drilled free of the rivet bodies to remove.
Edited by - Arlyn Stewart on 06/16/2014 08:05:47
