 Rope Clutch Slipping
c22sailor
Initially Posted - 05/26/2014 :  07:18:19  Show Profile
I am the new owner of a 2003 C250 WK. We took our first sail two days ago. The boat handled great. My only issue was with the rope clutch for the mainsail halyard. It would not hold the halyard tight. I am wondering if I have an issue with needing to replace the clutches inside, or if my halyard is too small for size of the clutch. Anyone know what size line the original halyard would have been?
Craig Lenfestey
1970 C22 #116
2003 C250 #665
c22sailor
Response Posted - 05/26/2014 :  07:47:53  Show Profile
I just found the answer to my question in the original owners manual. The halyard size is 5/16".
moserd
Response Posted - 06/03/2014 :  10:28:57  Show Profile
If you replace your halyard make sure you use a low stretch line. My clutch slipped from the very beginning (2005). When I replaced the line with the low stretch variant the problem completely went away.
c22sailor
Response Posted - 06/03/2014 :  15:26:01  Show Profile
Thanks for the comment. I reversed the halyard to try how that works. I know sometimes the halyard can wear a bit being stopped at the same place for a long period.
Response Posted - 06/03/2014 :  15:50:01  Show Profile  Visit britinusa's Homepage
Our Rope clutches effectively have a pump action.
Close the clutch most of the way down, raise it and lower again.
The 2nd time down holds the line much better.
ruachwrights
Response Posted - 06/09/2014 :  11:49:16  Show Profile  Visit ruachwrights's Homepage
Congratulations on your new purchase Craig!
Vern Wright
Hajime
Response Posted - 06/10/2014 :  04:19:11  Show Profile
I just learned that line clutches can be rebuilt. Annapolis Performance Sailing (APS) either has, or can order the parts. They made a video that shows how to rebuild one. This link will take you to the video. The prices for the parts don't look too bad, compared to the cost of buying a new one.
http://blog.apsltd.com/2009/03/video-blog-rebuilding-spinlock-clutch.html
Edited by - Steve Milby on 06/10/2014 04:57:42
c22sailor
Response Posted - 06/10/2014 :  19:18:13  Show Profile
I decided to go with a new Dyneema 3/8" halyard. I tried reversing the halyard, and pumping the clutch, with no success. It still slipped with the 5/16" halyard size. It is probably more than likely the line stretching when under load because the current halyard does not appear to be low stretch. I don't think I will have any more problems with the 3/8".
