 Rudder compatibility
jduck00
Initially Posted - 06/23/2014 :  07:57:24  Show Profile
Hey fellows quick question.
Were the rudders for the Catalina 25's the same throughout the years? I have an 1980 hull, but I've got a chance to buy a rudder off of a 95 model. Think it will fitwork?
Jeremy Duck
The Lucky Duck
1980 SKSR Hull # 1850
Response Posted - 06/23/2014 :  08:43:52  Show Profile
Hi Jeremy,
They didn't make a C25 in 1995 . . .
Perhaps you meant '85?
jduck00
Response Posted - 06/23/2014 :  08:59:21  Show Profile
I'll have to ask again. I'm pretty sure he said 95. Good info to know.
Response Posted - 06/23/2014 :  09:14:58  Show Profile
That would probably be a Catalina C-250, which went into full production that year. C-25 production ceased in 1991. The only change in the C-25 rudder happened in 1989, when the transom was changed and the rudder was modified to be "balanced." (A fraction of its surface projected forward of the pivot line.) Many of us upgraded our older boats to that rudder--like upgrading a truck to power steering.
While the C-250 rudder might be made to work, it wasn't made for the purpose. And there were several "generations" of rudders on the C-250 as Catalina tried to remedy some handling problems--notably "rounding up." If the '95 rudder is original to the boat, it's one that didn't work that well on that boat, which has a different hull shape from the C-25.
Edited by - Stinkpotter on 06/23/2014 20:50:15
