 One Battery or Two
Bruce Baker
Initially Posted - 02/23/2003 :  10:54:45  Show Profile
I've just bought a CD player for my boat, and I'm thinking of adding a second battery. I'm wondering if this is necessary and desirable? How many C-25's have made this conversion?
Bruce Baker
"Yee Ha"
Falls Church, VA
Response Posted - 02/23/2003 :  11:50:06  Show Profile
The necessity part of deciding on one or two batteries depends on your total amperage consumption and how long you need to go between chargings.
In it's simplest form, (no mid-trip recharging) you determine your electrical budget by multiplying the current draw of each electrical device (amps) times the number of hours it is expected to be used each day (hours) times the number of days you need to go between battery charges.
Example...
Cabin Lights 10 amps X 5 hours/day = 50 amp/hours/day
Anchor Light 5 amps X 10 hours/day = 50 amp/hours/day
Nav Lights 10 amps X 5 hours/day = 50 amp/hours/day
GPS 2 amps X 10 hours/day = 20 amp/hours/day
Depth 5 amps x 24 hours/day = 120 amp/hours/day
CD Player 10 amps x 5 hours/day = 50 amp/hours/day
Total daily usage... 340 amp/hours
So if your longest anticpated trip is 5 days, you will consume
1700 amp/hours. Divide this into 60% or so of your rated battery capacity. If demand exceeds supply, you need to add battery capacity.
Adding a second battery is relatively easy... and usually adds resale value to a boat. You need a mount, fusible link, and an A-B battery switch. Likely lots of articles on doing this out on the web already.
'78 Catalina 25
Ken Cave
Response Posted - 02/23/2003 :  13:31:22  Show Profile
It also depends on what size and type of battery you plan to use.
A typical wet cell will get harder and harder to charge to full capacity as it ages, unless you have one of those high amp chargers that can really zap it.
On my Catalina, I installed a series 24 gel battery as they are easier to charge and can take a lot of abuse without failing.
I did not have an electric start on my outboard, but I did have an Autohelm, GPS, radio, and lights (be careful on how you use the lights if they are the original.) and could sail for a week without a charge.
If you can get to a dock with electricity in a weeks time, one battery should be enough, as a CD player takes literally nothing to run them. I have a portable player hooked up to the radio in my present boat that I run on batteries. Have had the player for about six months and have yet to change the batteries!
Hope this helps
Ken Cave
tinob
Response Posted - 02/23/2003 :  16:29:21  Show Profile
HI KEN GOOD TO HEAR FROM YOU...VAL
Val Bisagni]<img src="http://im1.shutterfly.com/procserv/47b3df11b3127cce94709c5ff2e90000000010" border=0>
jsummerfield
Response Posted - 02/23/2003 :  19:27:34  Show Profile
I have a battery switch and two batteries. I thought that this was original equipment. I have an electrical start on my outboard and a VHF. I recommend two batteries.
Response Posted - 02/23/2003 :  23:12:47  Show Profile  Visit Leon Sisson's Homepage
Bruce,
If you have electric start (especially if there's no rope start backup), then I'd say it makes sense to have two battery banks. I have a dedicated cranking battery (group 24), and a house bank consisting of two group 27s. Another alternative for the house bank is an even number of 6V golf cart batteries.
As 'ClamBeach' said, it's a good idea to start by calulating your electricity budget, and go from there.
I suggest that anyone who has, or is considering, multiple batteries should look into battery combiners. Also, the traditional [OFF/1/BOTH/2] battery selector switches seem to be out of vogue these days. I think the latest recommendation is separate high current [ON/OFF] switches for each bank. A good combiner can be used for paralleling if needed in an emergency (such as house bank too drained to make one more batch of margaritas in the 12V blender and still run the stereo).
Bruce Baker
Response Posted - 02/24/2003 :  10:13:44  Show Profile
Leon,
Thanks for your input. However, I'm unlikely to encounter the type of "emergency" you describe. I've upgraded my 12V blender to one that can really crack some ice. Check this out:
http://gasblender.com/detailed.htm
Bruce
Kirk McKay
Response Posted - 02/24/2003 :  14:35:01  Show Profile
Ok, can you keep this thread going and let's hear what type of batteries everybody uses? I am now 100% sure my old wet cell battery is toast and will be purchasing a new one shortly. We will never be out more than a night or two, have electric start on the OB (with rope b/up)and don't use many electrical toys other than CD, VHF, depth and the minimum lights. Should we spend the bucks for a gel or stick with the wet cell?
Kirk
Response Posted - 02/24/2003 :  15:22:11  Show Profile  Visit Champipple's Homepage
While we are on the topic of electricity and batteries, does this diagram work (if one of you electrical engineering types could look at it I would appreciate it)
<img src="http://im1.shutterfly.com/procserv/47b3dc05b3127cce94988a3a0da00000001610" border=0>
What you can't see on this drawing - line connecting negatives on batteries...
DW
Bruce Baker
Response Posted - 02/25/2003 :  09:09:56  Show Profile
Duane,
I can't comment on the schematic based on my own knowledge, but you might want to check out the 12 Volt Bible for Boats by Miner Brotherton (available on Amazon). I got a coupon on the mail from West Marine last week (worth $10 off anything in the store) and I invested mine in the 12V Bible. I need to convert the three-wire system for my old mast to the new four-wire system on my new mast. Looking at the battery schematics in the book got me going on this topic in the first place.
Cheers,
Bruce
Buzz Maring
Response Posted - 02/25/2003 :  10:24:44  Show Profile
<font color=blue>I need to convert the three-wire system for my old mast to the new four-wire system on my new mast. Looking at the battery schematics in the book got me going on this topic in the first place.
Cheers,
Bruce
</font id=blue>
Hi Bruce,
I need to do the same thing. When you "crack the code," would you please post it on the Forum?
Thanks!
Stu Jackson C34
Response Posted - 02/25/2003 :  13:03:47  Show Profile
Duane's Sketch
Duane, it looks OK as drawn, and will work. However, why bother with the battery isolators? They take about a volt right out of your charging system. The simplest thing to do is to run the red wires from the charger to the 1-2-Both switch and use the switch as the method to choose which battery or both to charge. As long as the charger's on long enough to top off the batteries, you won't have one draining into the other without getting them both up to snuff. An alternate choice would be a battery combiner with the charger going to the house bank. However, I don't know if you're using one battery as a satrt bank and the other as a house. Just diss the isolators, they're ancient and not very helpful in charging, and will almost assure that you are chronically undercharging your batteries, which isn't very good for them. Any further questions, let me know.
Stu
John Mason
Response Posted - 02/25/2003 :  14:25:12  Show Profile
The four wires up the mast are Green-Ground, White-Bow light, Orange-Anchor light, Yellow-Deck light.
Here's the link to the schematic - http://c25c250.best.vwh.net/restricted/4-2-4.gif
John Mason
<img src="http://www.users.qwest.net/~jamason/ali.jpg" border=0>
pronounced "Ali Paroosa"
1982 - FK/SR #3290
Carl B.
Response Posted - 02/25/2003 :  22:57:47  Show Profile
Has any one had any luck pulling new wires thru the deck were the old wires ran? If so what is the trick?
"OBLIVIOUS" C25 '82 #3098 SR/FK/Trad
John Mason
Response Posted - 02/26/2003 :  11:54:12  Show Profile
When I rewired my mast, I had to run the wires along the top of the bulkhead in the head area. Just drilled a hole angled forward down through the original deck plug "platform" on the deck. The original wires are sandwiched in between the bulkhead and the cabin top. Unless you want to remove the chain plate, bulkhead, etc., they're inaccessible.
On my boat, the old wires wouldn't budge, so I couldn't feed new wires through that way.
John Mason
1982 - FK/SR #3290
Edited by - John Mason on 02/26/2003 11:56:12
