 Repairing Leaking Thru Hull
Bruce Ebling
Initially Posted - 03/01/2003 :  20:24:18  Show Profile  Visit Bruce Ebling's Homepage
Has anyone had any experience repairing/replacing thru hulls?? I may have a thru hull that is leaking. Any help would be great.
Bruce Ebling
89WK "Selah"
10timesSaltier
Response Posted - 03/01/2003 :  23:11:19  Show Profile
Bruce,
This shouldn't be too big a job. I had both my "to-hulls" and gate valves replaced with new "thru-hulls" and ball valves for $125. If you already have true "thru-hulls", maybe they can just be rebedded in 4200 and tightened down?
If your '89 (sorry I don't know when Catalina stopped installing to-hulls) has "to-hulls" and one is leaking...I would replace it and SOON! If your boat has gate valves I would dump those as well.
Brian.
Great Salt Lake (10-times saltier than the ocean)
"SAFARI", C25 TR-FK #2275
Response Posted - 03/02/2003 :  12:31:45  Show Profile
Bruce has thru-hulls. If they're like ours on our '85, they're flush to the hull, with countersunk flat disks on the outside (instead of domes).
Bruce: Is your leak around the base, or could it be in the valve or at the hose clamps? Are you double-clamped on each hose?
Bruce Ebling
Response Posted - 03/02/2003 :  14:27:32  Show Profile  Visit Bruce Ebling's Homepage
At this point the boat is on the trailer waiting for the resevoir to fill. When I bought the boat (Salt Lake City) it has some water in the "V" berth area. Yesterday I was looking at the holding tank and valves and noticed one of the valves had a wood plate that it was bedded to. The wood looked in bad shape. I thought that maybe water had leaked into the forward area by means of the rotten wood. I will not be sure until the boat is re-floated in April.
Gloss
Response Posted - 03/02/2003 :  18:48:38  Show Profile
Hey Bruce
Did you know that only 223 89 Wings were built?
We are truly lucky to have one
Frank Gloss
89WK/TR
Richard Tripp
Response Posted - 03/02/2003 :  19:40:21  Show Profile
Bruce We are new & had a leak in the v berth area also. It turned out to be the gate valve but I had the boat out of the water by then & had ordered the kit from Catalina direct. It had everything needed including the wooden backing blocks & instructions. Following instructions I had no problems & now have new thru hulls & ball valves. No leaks & I sleep better at night. I even built my confidence to the level that I am now in the process of replacing the bladder type holding tank with a new solid wall heavy duty tank. Good luck and just do it. dick t Windtamer in the water at Lake Mead.
Response Posted - 03/03/2003 :  15:50:42  Show Profile
...When I bought the boat (Salt Lake City) it has some water in the "V" berth area. Yesterday I was looking at the holding tank and valves and noticed one of the valves had a wood plate that it was bedded to. The wood looked in bad shape. I thought that maybe water had leaked into the forward area by means of the rotten wood. I will not be sure until the boat is re-floated in April.
Bruce: Did the boat sail on Great Salt Lake? If so, check for saltiness in that water under the v-berth. A common source of water under there is a leak in the anchor locker--especially at the drain tube at the bow. In that case, the water will be fresh (unless you bury your bow in some big breakers). A little caulk on the finger tip, applied inside the locker, fixes that one.
f_sondergaard
Response Posted - 03/07/2003 :  20:40:28  Show Profile
Bruce,
I agree with Dave on the anchor box. We have problems with water coming into the v berth just after very heavy rains. The anchor box gets backed up with water and leaks into the v berth storage area.
Jason & Fran
1982 Catalina 25
Swing to Wing
Douglas
Response Posted - 03/08/2003 :  23:30:13  Show Profile  Visit Douglas's Homepage
Don't wait to put it in the water to see where its leaking from. If the wood looks roten it probably is. Do an archive search on the subject and try (bottom rework) I have done all of the valves. Its ver easy if you use the right tools and have some idea if what your getting into see the attached pictures for example. I would be glad to help if you E mail me.<img src="http://im1.shutterfly.com/procserv/47b2dd35b3127cce9ca14d9e7ffe0000005610" border=0><img src="http://im1.shutterfly.com/procserv/47b2dd35b3127cce9ca14d85fed50000005610" border=0><img src="http://im1.shutterfly.com/procserv/47b2dd35b3127cce9ca14d8c7fec0000005610" border=0><img src="http://im1.shutterfly.com/procserv/47b2dd00b3127cce9d5f16f10df40000005610" border=0><img src="http://im1.shutterfly.com/procserv/47b2dd00b3127cce9d5f160f0d0a0000005610" border=0><img src="http://im1.shutterfly.com/procserv/47b2dd00b3127cce9d5f16fa8ccf0000005610" border=0><img src="http://im1.shutterfly.com/procserv/47b2dd00b3127cce9d5f16028c370000005610" border=0><img src="http://im1.shutterfly.com/procserv/47b2dd04b3127cce9d4cdf90ce590000005610" border=0>
Doug&Ruth
Triska (Alberg 29)
Tacoma Wa.
Douglas
Response Posted - 03/08/2003 :  23:42:24  Show Profile  Visit Douglas's Homepage
The volcano is cut of with a 90deg grinder. The area is then ground flush but be carefull to only remove as much material as needed. To remove the part of the tube left in the hull use a hacksaw blade and glove of hacksaw type knife saw. Once you have cut a slot you can curl and punch out the metal pipe with a punch and chisel. Clean out the fiberglass hole and boar it to size. You can use a rotary file in a drill or you can bang in a wood bung from the outside and cut it flush and then use a whole saw. Cut the hole slightly larger than the new through hull. Seal the new hole edges with resin or epoxy. Install the new through hull fitting with lots of 3M 4200 or Sikaflex 4200 lots of seal on the outside fitting before it goes in. Have someone hold it or use a prop. Go inside and seal around the fitting and hole and then install the gland nut. Finger tight or loose. wipe up the mess outside and in an let it set overnight or longer if cold. Tighten up the fitting only after the exterior seal has set up to 3/4 hard. This alows for a better seal and some squeez out. Clean up the exterior again and let it all set up. A little heat might help but not to much.
Doug&Ruth
Triska (Alberg 29)
Tacoma Wa.
Response Posted - 03/09/2003 :  13:07:02  Show Profile
Hey Doug...
Good shots! But if you insert a "new line" character between some of those pics, you can narrow down this thread a little.
