 centerboard lifting pennet
mdidomenico
Initially Posted - 03/24/2015 :  14:22:25  Show Profile
apparently, my lifting pennet is in severe need of replacement. since i'm up on the hard over the winter it's pretty easy to see that it's only holding on by a few strands of the wire
i see catalinadirect has vectran ones. has anyone used these?
i'm a little apprehensive given that the rest of the hardware is all brass, seems like chafe would be an issue
dubedoo
Response Posted - 03/25/2015 :  15:18:33  Show Profile
Hi?
I have the 5mm vectran. Installed 9-10 years ago along with a replacement block (the 5mm replaced 3mm vectran). No problems. Will be checking it for wear again this year. There has been just a little wear/chafe around the brass turning ball but that vectran has been tough stuff. I raise and lower the centerboard quite often so I really give the lifting tackle a workout.
Info from owners manual updates lists Catalina using vectran (3mm) rather than wire starting 7/15/99. They went to 5mm vectran 10/7/03. The Catalina Direct kit appears to be a retro fit kit with appropriate replacement block for vectran. I'd say having already gotten 9-10 years out of it is doing good. I also measured the length and ordered an extra piece of vectran from West Marine so I have it when I need it. Good luck.
Steve C250 WB #702
mdidomenico
Response Posted - 03/27/2015 :  06:34:42  Show Profile
Thanks for the info. I wasn't aware that catalina shifted on the later models. I don't move my centerboard all that much so hopefully if there is a chafe problem it wont rear it's head until the following winter. :) if not, then i'll short haul and replace it. :(
Response Posted - 03/27/2015 :  08:00:04  Show Profile  Visit britinusa's Homepage
If the boat is out of the water then best to take advantage of the easy access.
Stitch in time etc.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
zeil
Response Posted - 04/11/2015 :  16:56:55  Show Profile
Old...
New...
Henk & Johanna
mdidomenico
Response Posted - 04/18/2015 :  18:47:46  Show Profile
Thanks for the replies. i did end up ordering the replacement vectran line kit and brass sheave. we'll see how it works out.
is there a reason for the snatch block you used or is that standard equipment that came with the boat? mine came with a small harken carbo block.
zeil
Response Posted - 04/19/2015 :  17:58:21  Show Profile
It was the original block that needed, in my opinion, replacement (see previously posted photo) It created a lot of friction adding to the load of hoisting the centerboard. Since we found the, albeit somewhat over-sized, open block it could be installed without detaching the attached Vectran cable...
Brass turning ball... looking down through up-haul tube while the boat is in the water. It took a diver only minutes to attach the Vectran cable to the center-board and connect the cable to a fishing line to be pulled up through the tube into the cabin to be attached to the up-haul mechanism.
Henk & Johanna
